white smoking coming from exaust
?? anyone know what this is from? it only comes from the tailpipes..
maybe i'm burning oil? that was my 1st thought...
anyway any help in needed...
Oh, btw, the engine is a 301 4bbl.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Blue = oil.
White = water/coolant.
Black = unburnt fuel.
A shop can do a combustion products test of the cooling system. May be a head gasket, may be a cracked head.
Originally posted by five7kid
Blue = oil.
Blue = oil.
also, my carb is totaly screwed, would that have anything to do with it?
i hope its not a cracked head...
Car: 89 GTA
Engine: 406 SBC
Transmission: TH350
I know this sounds like one of those oversimplified solutions, so forgive me if I insult your intelligence.
Here in Minnesota, "white smoke" comes out everyones exhaust when it is cold enough outside. Warm engines and exhaust collect moisture when the car is shut off. When you finally restart the hot exhaust gas reheats that moisture and it comes out the tailpipe. We get a lot of this white smoke when the engine starts, and sometimes it goes away, sometimes it doesn't depending on the humidity and the temperature outside. If you are smoking going down the road and no one else is, it could be a problem.
water leaking in to the combustion chamber be it a cracked head or blown gasket will overheat an engine, even in the dead of winter.
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
don't know how well this would work for you
but what you might be able to do is WHEN THE CAR IS COLD take the rad cap off the car start it and let it warm up
if you see a lot of bubbling in the coolant and foam or worse yet gyeser like stuff shooting out like a foot high you prolly have a blown head gasket I woudl think
don't know how well this would work on a piston motor but on a rotary it works when the coolant seals go which are just like your head gasket pretty much.
combustion pressure pushes past the seal into the coolin system getting released by none other then your rad cap that isn't there
if anything it should like just like a nice smooth stream though once everything warms up but I wouldn't recomend leaving like this for long after the motor is up to full operating temps
another thing maybe smell the exhuast
thats right put your hand right down there and take a good ol' wiff
sometimes it's hard to see the difference between the blue exhuast and white coolant unless you look at it just right
but by smell coolant has a sweetish smell to it while oil I'm sure you know what it smells like
if nothing else
have you checked your oil level or coolant level in a while?
if nothing else
it doesnt smell "sweetish" at all...more like oil...
this is on a car that hasnt run ina 1 1/2 years....so...maybe it just need a good running?? plus i'm going to rebuild the carb...maybe that will help..
Car: 1986 Camaro IROC-Z
Engine: 350TPI
Transmission: TH350 w/Stall & Shift Kit
If it only does it at startup maybe bad valve seals? If its a bad head gasket wouldnt you be running hot?
Engine: 3.4lL 60* V6
Transmission: Tremic TKO 600 RR
How is you coolent level?? I had a head gasket go and the white smoke is a lot more then what you see when the car is just warming up.
Its a lot of white smoke ? even after the car is warmed up well, my friend would say it look like cotton coming out of the pipe..
Paul
Paul
Car: 87 Black Formula
Engine: Rollercammed Lg4
Axle/Gears: 3.23 10 Bolt Locker
If you havent ran the car for 1 1/2 year, do you still have the old gas in there? If the tank is not full when you park a car for a long time, condensation will make the gas contain some water in time. Other than this, gas is supposed to have a limited life, and 1 and 1/2 years is way over the limit.
I had a car once who had only been parked for 6 months, but the first thing I needed to do to start driving it again was to have it inspected and smogged. Of course it failed, even though I had done nothing to the engine since the last pass. I drove for two days, filled up with new gas, and then it passed.
I agree with the others on this, white smoke is water or coolant coming into the combustion. The question is only how.
the gas prolly 8-9 years old...because the guy had it before me said it sat for 7 years....but it wanst smoking when i i drove it home... maybe it wasnt 7 year old gas...but still...yea the gas tank was only 1/2 full while it sat
That is hard to beleive that the gas was that old and that the car ran, or that the gas was still there after all that time
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
White "Smoke" can only be coolant or a deteriorating aluminum component such as a valve or piston (catastrophic)
