can a 3" exhaust support 450hp?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 89 Formula 350 WS6
Engine: 383 miniram
can a good 3" single mandrel bent exhaust with dual hi-flow cats, high flowing muffler and 1 3/4" headers efficiently support 450hp or more with minimal losses? what kind of gains could be expected for going to 3.5"?
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Based on your previous post about headers, I'd suggest you cut to the chase and go long tubes (1-5/8" would be fine for that power level in LT's, but 1-3/4" would do the trick, too), Mufflex Y, and 3.5" or 4" on back. Or, 2-1/2" duals all the way back.
If this is a regular street warrior, then you'll have to choose between ground clearance and peak power.
Engine: 383 miniram
yup, its for street but obviously im looking to maximize peak power here and keep it all legal. so longtubes are out, so is dual exhaust.
im just curious as to why traxion was able to have such obviously ridiculous hp with a single 3" exhaust. thats the main point here i guess. that, and i understand a slightly narrower pipe will maximize scavenging and keep the gasses hotter and flowing faster, as well as keeping the noise level down somewhat, which are also goals. i realize im juggling here but its all about compromise anyway. i just want to choose the best options.
im not going for 500hp obviously, im running a superram, not a miniram. but if i can get damn close to 450hp with this setup, and i believe thats doable, then i want to do just that.
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Engine: 383 miniram
interesting. what head/cam package are you running in the 406? which shorties/y-pipe did you choose and have you had it dynoed or tested for backpressure? what trap speed are you running?
Engine: 383 miniram
Originally posted by CaptPicardsZ28
Hooker super comp shorties w/ypipe, no backpressure and no trap times yet.
no backpressure at 500hp? how did you determine this?
sailtexas186548
02-17-2017 03:07 PM
