hooker 2055's or Hedman?
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
read the sticky article up top, just wondering which of these two do most people find better. In your opinion, would modifying the Hedman ypipe to 3" outlet make it as good as the Hooker ypipe?
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
yeah i am in the same boat no experiences with the heddmen's but i love my hookers.
Engine: LB9/383
I like the hookers, but the problem is they come with air fittings. I'm a JetHot dealer, so they'll be coated which presents a problem in that I can't cut them off and weld them shut without messing up the coating. Only reason I'm thinking about the Heddmans is b/c they're the only ones I can get with a ypipe and no emissions.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Couldn't you request having the tubes cut off before coating? I assume JetHot takes special requests. Or, buy the headers yourself, cut/weld the A.I.R. tubes, then send them for coating.
That sounds like a lot less hassle than modifying the Hedman y-pipe.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Originally posted by rsn932
site sponsor ACS will cut the tubes off before coating them
discount for being TGO member too
Engine: LB9/383
Nothing against ACS, but JetHot is alot cheaper and since I'm a dealer, I get a pimp price. My rep owes me a favor.
no green
01-09-2016 09:22 PM
