Installation of Edelbrock TES Headers...
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
Ok for you guys who have these headers, can you please tell me the installation process. I bought mine used and i woudl like to know if its just a matter of unbolting the exhaust manifold and botling these on or do you gotta move stuff in order to get them in and out?
The guy who was gonna help me cant now, deployment to the gulf.
So i might need to try something myself.
Shane
Shane
1 Post
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I don't know if they will bolt onto the exhaust system you have, but as far as bolting them to the heads, then yes. You just take off the old manifolds, and put the headers in their place. Just make sure you have real header gaskets, not manifold gaskets.
You should have a new set of bolts for your headers too, don't reuse the stock manifold bolts. WAY too long.
Car: 1986 Trans Am
Engine: 305 LB9 TPI
i got a mr gasket header gasket set, round ports.
i'm gettign the flange gaskets, botls, and donuts soon.
Car: 83 Z28, 84 Z28
Engine: 5.0 Cross Fire, 5.0 H.O.
Transmission: 4 Speed Auto, 5 Speed Manual
im in the process of putting a pair on my 84 camaro, its a pain in the A$$, the passenger side is a piece of cake it slips right in with room to spair, but the driver side it hits the brake lines and stearing column, so ur gonna have to bend the lines out of the way and take that stearing column out. Also im having a problem re-mounting the power stearing pump, so be prepared for that.
Car: 1987 Trans Am
Engine: tree-fiddy
ok, can some post a link to where i can get the correct bolts for these? I found the gaskets, I just need the bolts.
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
I think you have to modify that bracket to get it to fit right. Thats what it says in the instructions.
Car: 83 Z28, 84 Z28
i was in the process of redoing my heads, so i already had everything out of the way (power stearing, alt, smog pump, A/C, etc) for when i installed my headers. I also got an edelbrock water pump which has spacers too, and figuring out where they go is the pain in the a$$. but yea the passenger side was a breeze, the driver side is not so bad after u get the stearing column out of the way.
I didnt put the o2 sensor back in yet cause i didnt have one to put in while I was putting the driver side header in, so im just gonna get it in from undernieth.
What bracket are you talking about, i havent had to modify any, yet.
theshackle
09-17-2020 08:26 AM
BlackphantomZ28
08-22-2015 01:00 PM
86IROC112
08-17-2015 02:00 PM
305, ac, bracket, brackets, camaro, edelbrock, gains, gen, header, headers, headersthirdgen, install, installing, instructions, tes
