Modified 305...can I use a cat converter?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 82 Camaro; in process of resto
Engine: 350 4bbl.
Transmission: 700R4 with B&M Lockup
Axle/Gears: Moser 28-spline axle; 3.23 gears
All,
I'm running a 305 that has been de-computerized all the way around. I no longer have the AIR, EGR...it all went bad, and I couldn't afford to keep up with that rich man's game. My cat has finally rusted through, and I have to replace it.
What can I replace it with that won't get clogged without the O2, AIR, etc.? Am I stuck with going to an X or H pipe from my headers to the rear? Not that I would mind making it dual, but I've never welded. If I buy a cat system, I can just take it somewhere.
Any advice?
Any advice?
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I would look at any cat that does not come with an AIR tube. Your cat will only clog if you have incomplete combustion (ie. excessively rich or lean). If your carb is tuned right than you shouldn't have any problems. Most cats will clog if you run more than 1% away from stochiometric for long periods of time.
Hotrodboba400
12-10-2019 07:07 PM
rudolphschenker
09-04-2015 02:41 AM
