Routing around Smog Pump
I badly need a new serpintine belt before mine goes while I'm driving. I was looking at the Tech articles and found the article on routing the belt so that it would work without the smog pump. Could I buy a new belt the right size that the article says to and put it in, leaving the smog pump in place with everything hooked up. I'm getting new headers in June off my buddy and they don't have air tubes. Would it be ok to leave the pump on and not working till then but replace the belt now?
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I do not think you can re-route it. It is right in the way and stick outs even with the pulley off. I would just leave it be until you can remove everything. Hopefully your belt will last that long.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Originally posted by Farfire70
Will I get a code if I remove the smog pump. I've searched the forum but gotten conflicted information. Anyone know?
awesome, looks like i have a weekend project. Would it be a bad idea to rip everything out now or should i just rip out the smog pump and leave everything else till i add my headers.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
what should i plug them with?
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
could I use a rubber stopper or something like that?
