side pipes???
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Originally posted by AZCamaroPhreak
side pipes on a camaro hmmmm.... they dont look very attractive
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
'70 Challenger TA style is cool (tips poking out) but 427 Cobra style just doesn't work on F-bodys.
actually the side pipes got me thinking a little more, for a muffler you can build one similar to what NASCAR uses for their exhuast tubing or square flat tubing. that is to say if you have the tools to make a flat muffler. It would a good short cut if you dont plan on having a shop make your exhaust, or you are using short headers and running true duals that dont go into the factory location, or you just dont feel like running the tubing under the rear axle. sortta like what i have done using the area under the driverseat i plan on using heat shields and making a thin-line cat fit under it.
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
Car: 70 ta 70 camaro
Engine: 455 383
Transmission: 4 speed
i should have said side exit i dont like the big pipe running along the side but a flat pipe just coming out would be cool and sound great i think does anyone have a picture of this
Originally posted by 25THRSS
nascar doesn't run mufflers. They don't run anything but straight pipes
NO DUH i didnt say they use a muffler what i said was you could try building a muffler similar to what nascar uses for exhaust tubing.
side pipes
I think the side pipes on the z28 look great. Can't find much info however. Only source seems to be older corvette sites. I have only seen one in person and it looked and sounded good. Plus eliminates all the dual exhaust hassle under the car. Ground clearence must be an issue but I have welded sub frame connecters so I am already lower than most. Anyone have more pics and tips?
Car: 89 Formula L98 power
Engine: '96 subaru, opposed 4banger
Transmission: TH700R4, subaru 4WD
Axle/Gears: 3.27, just works
I know a guy with an 88 IROC-Z and a 502 big block with lots of work putting out just over 654 hp at the flywheel. And this car was also the runner up in this last summers super chevy show, for best prostock of show. And he has a 4" collector and a 3" pipe dumping down and towards the outside of the car, and he has no problems with ground clearance. His car should also run in the mid 9's as it sits, and runs on 93 pump gas, and idles like a bear, he sat in the line to get into route 66 for an hour and a half, with the car running, and it never overheated.
heres the motor.
heres the motor.
has anyone ever used 76-81 trans am exhaust tips for side exit exhaust i think it would look awsome heres a set on ebay http://cgi.ebay.com/ebaymotors/ws/eB...tem=2461106818
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
yeah, they run a muffler by dr. gas, the same people with the innovative x-pipes utilizing all kinds of tubing...
www.drgas.com
www.drgas.com
www.drgas.com
thats true to an extent, however alot of the throttle stop and 8.90 second brackets classes, and other classes require a muffler. But when your running a car that runs 8.90's, its obvious the bullet muffler is your best muffler.
Engine: 7.0L
Some specific classes might at certain tracks where noise is an isisue, but I was referring more to the nextel series. Go to a race some time. Hang out in the pits. They don't run mufflers period. The noise is part of the attraction.
naw, i will let you hang out with the nascar croud, i would much rather go street legal drag racing with the nsca with a mandatory muffler rule...
Car: 83 Pontiac Firebird S/E
Transmission: Borg Warner T5
Hey, I have always wanted to do some side pipes, and that first picture with the 427 style is what i always wanted to do, but now that i look at it, it aint that great, not bad tho. I have a question for you guys. I want to put pipes coming out the sides of my car, right before the rear tiers. I have true dual exuast set up right now, shortys, and some pipes, i found in a yard. 12 bucks! Anyhow, right now the pipes go to the passanger side together, and i am dirving around with straight pipes, nothing but, no muffler no cat. Loud as ****, and i am gonna get pulled over soon. I was wondering what type of mufflers i could run along each side, and still have a great nice loud sound. Keeping the true dual. Are those red glass pack mufflers any good at shucks ? They are long and thin, so they would prolly work well, but how do they sound? Anyone know? Also i am not gonna use any CATS. Thanks
Side pipes
I agree. I at least want more info on the pipes because the body style looks like a good fit for them. The first picture is what I had in mind but they need to be tucked in a little more. What about heat shields under the ground effects panels? Are they necessary if you tuck them under the body a little more? I'm sure there are mufflers made that would work. Like I said before I have seen one car with them. They were chromed and had at least one header pipe visable in the wheel well on the passenger side where our y-pipe comes out now. I'm sure he had to do some mods in the engine bay and/or wheel well.
Terrell351
06-13-2021 01:13 PM
hectre13
09-08-2015 03:38 PM
transaero
08-31-2015 01:14 AM
