Best Flowing Mail order Exhaust
1 Post
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
I need an exhaust that runs in the stock location over the axle and exits at the rear either to one side or duals, the important thing is for it to flow well, and I'd like it to be loud also. It will be welded to the 3 inch pipe I have coming off the hooker 2055's in place of the cat. Right now I have a 2.5 inch I-pipe and it seems restrictive. I Need it to come in the mail preferably from Jegs or summit and price is not really an issue. Part numbers would help. Heres some I'm considering
-Flowmaster 17233
-SLP loudmouth
-Magnaflow LS1 15684
-Borla
-Edelbrock 5672
-Hooker 16823
-Flowmaster 17233
-SLP loudmouth
-Borla
-Edelbrock 5672
-Hooker 16823
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Flowmasters are proven to be the worst flowing exhaust compaired to other after market brands. You cannot go wrong with Hooker, Magnaflow or Borla. That would be the list I would choose from. The loudmouth may be what you are looking for. It is obnoxious when you have any motor in front of it. Especially without any cat to muffle it. It will take a bit of fab work to use a 4th gen system but plenty of members have done it. Beware though, as I have heard a Hooker long tube/no cats and loudmouth equiped LS1 and it sounded HORRIBLE. It was louder than a racecar and had horrible popping and rasping sounds SCREAMING at you from all angles. I actually had to plug my ears while I was driving when he took off. You wouldn't think that a motor that makes 350hp would sound so horrible with such a free flowing set-up. If you want loud I would get the loudmout, but I would run a cat or weld another resonator in the I-pipe to dampen the brutallity of it.
1 Post
The hooker cat back system looks good but is it a 3 inch y-pipe? And how does it sound at idle and at WOT?
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
It has a 3" piping all the way back. it does not come with a y-pipe. You already have that on your Hooker 2055's and that is 3". You just need to fab up a 3" extension pipe to go from your y-pipe to the cat-back.
The best flowing would have to be the borla with no plate. Basically it's like having a cutout. Second would be the loudmouth seeing as it has no muffler at all and just a resonator. The rest are probably a toss up.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Here is a pic of my hooker cat back where it connects to my y-pipe. You can see where it reduces from 3" to 2.5. My y=pipe is smaller than the cat back and cat so there was a need for a reducer.
Car: 91RS
Engine: 305tbi
1 Post
Cool. Geez your car seems low. I used to have a reducer from the hooker y-pipe to the stock cat before I just cut the cat off completely and replaced it with a 20 inch section of 3inch pipe. Seems like the hooker and the flowmaster systems have mandrel 3 inch pipes the only difference is the muffler. How does an aerochamber muffler compare to the 80 series?
Car: 90 Formula, 02 ws6
Engine: 305 tpi, ls1
Transmission: 700r4, t-56
Axle/Gears: stock posi 2.73, 12 bolt with 4.11s
the flow master sounds really good with headers and no cat
thats the setup on my 89
it has to flow better then stock atleast pule i have alot of leaks right now haha
i have the loudmouth on my 2002 right now and its sounds bad *** but im puting on hooker LTs and no cats so i might have to keep that exhaust for a lil while but im doing dual sut outs in the y pipe so im going with a hooker car back, B&B catback, or duals maybe
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Well..... with price not being an issue at all, the Mufflex 3.5" or 4" systems will blow away (ba-dump....tssshhhhhh) any 3" system....
You can purchase directly through them and have it shipped to your door. They offer those single outlet (do not bother with a crossflow if you want the best flow possible) large diameter systems with Flowmaster or Spintech mufflers.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
im might be doing it only temporary i have no desier to leave it like that
my friend has the same set up and it is to much
1 Post
Car: 2007 Saturn Sky Redline
Engine: 2.0 turbo
Transmission: m5
Axle/Gears: 3.91 LSD
Best sounding is without a doubt the Hooker. It's 3" all the way back with a dual outlet for the classic look. I would recommend it over the crappy sounding drone of the flowmaster and it's far cheaper than Borla.
Car: Check The Sig
For the price, you cant beat Hooker. Great sound at WOT and improves over time, good look of the 4x3inch tips out the back, and great flow. But for the price, a moddified LM from SLP is probably the best flowing as there is no muffler or anything, just an enlarged 4inch section of the I pipe. Flows are fine, but everyone and there mother has them, and they dont really master any kind of flow, for third gen and 4th gens away. If you want stainless, and cheap, PM subzero and get the p/n for the Banks Cat back. Its 3 inch all around with 2.5's out back. I belive he said he got it for something like 260 shipped? You need to talk to someone that knows about it at banks as they dotn show it on there web site and most peopole there dont know about it unless you have a p/n. It all comes down to how much you wana spend.
People........ shut up about what sounds the best. That call is entirely proprietary to the owner of the ear a given exhaust sound is entering .
The best flowing is the biggest system you can get and, in this case, given that we are talking about mail order, that is the 4" Mufflex. Period. End of story.
1 Post
Engine: 2.0 turbo
Transmission: m5
You don't need a big block to need big exhaust. I personally know of many, many small blocks that make more power and move more air than some blown big blocks. It's totally situational.
Over 3" is unstreetable???? I drive my 4" on the street primarily and I know of at least two more in my city that do as well. And how unstreetable are all of the other types of vehicles running around with DUAL 3" systems?????? My 4" single is no louder than my 3" American Thunder system..... It sounds entirely different but is really no louder.
The bottom line is the guy asked what mail order system flows the best. The answer to that question is one of the 4" systems. Most of you...... well....... are pimping your favorite products or mixing in a defense for your lack of using the best flowing exhaust possible. Not to be harsh, but there it is.
1 Post
Engine: 2.0 turbo
Transmission: m5
Fact is every 4" I've heard on a small block sounds just as loud as running open headers except more tinny. If all you're looking for is flow why not just run uncapped long tubes? Same ground clearance plus it's cheaper and sounds better than a 305 through a mufflex 4".
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Tim
Me and other guys I know have ran 11's and others I know have ran 10's with a 3" setup. The ATR Performance Pit Bull cat-back setup has had people go 9's with their 3" setup, http://www.atrperformance.com/index.php?cPath=2_24 . Alot of Turbo Buick and LS1 guys I know love the ATR setup. It's a nice all stainless cat-back with a pretty mean sound. Futral Motorsports' site I believe shows a video of their 10 second car with the ATR setup. http://www.futralmotorsports.com/ss_mods.htm
1 Post
Car: 99 Formula
Axle/Gears: 342
People, let it die. I "bottom lined" this topic already and, given the subsequent replies, I have to say that I did indeed hit the nail on the head:
1 Post
Car: 99 Formula
Axle/Gears: 342
1 Post
I have heard that cross flow mufflers are more restrictive than sraight though ones, is this true? I really want the Hooker cat-back but not if there is a better flowing one out there besides a 4 inch one.
Any straight through flowing muffler will outflow a crossflow. Pretty simple concept, there are less turns to make, thus they flow more.
You can get single outlet systems with straight through flowing mufflers in pretty much any size you want. Flowmaster sells a 3" and Mufflex has 3.5" and 4" systems...... There are likely others but those are off the top of my head .
Street Lethal
04-30-2019 12:14 PM
