Insulation for spark plug wires because of headers ?
Car: 1983 Z-28
Engine: 305 CFI
I just finished intalling long tube hedman headers that are wrapped with insulating header wrap. I was wondering if you can buy insulation for your spark wires and boots because my wires are pretty close to the tubes, and one of them melted onto the headers (luckly I dont have the new wires in yet).
I also need insulation for my remote start solenoid wires.
Any help would be appreciated.
thanks
thanks
you shouldn't have the wires that close to the headers....in any event they do make certain things that i've seen on the internet but unfortunately i can't remember. i'm sure someone here will know.
Car: 1983 Z-28
Engine: 305 CFI
plugs
yeah, I know that they shouldnt be touching, but I am worried about heat soak. Even the part of the wire that was farther away seemed pretty hot to me.
Car: 85 Z28
Engine: 383
Transmission: TH350
Axle/Gears: 3.73 posi
Check out this link to the summit online catalog, they have plenty of products to overcome your current problem. Or just search for "Spark plug boot heat shield". Good luck.
http://store.summitracing.com/defaul...rt=heat+shield
Car: '85 Z28
Transmission: WC T5, 3.23 posi
Summit and Jeg's have a wide supply of items that would solve your problem, however it will be a bit costly. I would reccomend instead you get some wire looms (or make them yourself) to hold the wires away from the headers. My car doesn't have anything protecting the plug boots, just well placed wire looms and I haven't had any damaged so far.
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
i got these plug boot protectors from DEI through summit...
they work good.
-brian
they work good.
-brian
the number 7 plug on my engine is so tight....that i have to grind some of the plug electrode off in order to get the boot in far enough....then shave some of the boot....so there is about an 1/8 of an inch of clearance or so.
it wont melt, but after a year or so it will get brittle from the heat and crack......i use the moroso race wires......the boots are really, really tough.....as long as its not touching it shouldnt melt.
1992 Trans Am
05-10-2023 07:19 PM
eightsixseven
08-14-2015 03:09 PM
