dual exhaust and body squeaks fix
Old 08-17-2003 | 02:51 PM
MechCD's Avatar
Car: '92 Camaro RS, '93 Ranger
Engine: LO3, Vulcan
Transmission: 700R4, M5OD
Axle/Gears: 2.73, 3.45
I finally got my suspension all back to normal and working right, and I was still hearing a squeak in the back on turns. It didn't happen on bumps, just turns.
I took a look under the rear, and my dad was nearby and bumped the passenger side exhaust tip. There was the squeak. The problem I had was that the passenger side exhaust was very close to the spare tire compartment and it hit everytime i went around a corner. I cut a piece of wood to fit and put a notch on it. The flat part touches the exhaust, and the notched part slips onto the lip of spare tire compartment. I could grab a pic if that sounds confusing.
Hope this helps someone!
Old 08-19-2003 | 01:43 PM
SHAGME's Avatar
Car: 1988 IROC-Z
Engine: 355ci TPI WORKED TO THE BALLS!
Transmission: 700R4 T-56 coming
Wood and hot exhaust pipes dont go well togeather do they?
Old 08-20-2003 | 09:26 AM
MechCD's Avatar
Engine: LO3, Vulcan
It hasn't burned yet
I really doubt something bad would happen with the placement of the wood. If the exhaust got that hot, wouldn't the hot air melt the rear bumper?
Old 08-20-2003 | 06:55 PM
yanfoo's Avatar
Car: Malibu 80, T/A 87, S-15 87
Engine: 267 Bu, 305 T/A, 350 S-15
Transmission: Auto Bu, 5spd T/A, Auto S-15
rubber peice would always be better, and reduce noise... you could cut an old tire...
my exaust do get real hot! can't touch bare hand after a ride.
Old 08-20-2003 | 06:59 PM
bes217's Avatar
My muffler and tail pipes don't get hot at all even if I drive around all day. There is a little warmth there but not a lot. I can touch my bare hand to the muffler and not get burned.
Old 08-20-2003 | 07:09 PM
yanfoo's Avatar
maybe, but it depends whats the setup...
i only have turndown on my mufflers, so not much to grab, so close its hot hot!
customblackbird
08-15-2021 11:16 PM
Vintageracer
01-10-2020 06:33 PM
Street Lethal
04-30-2019 01:14 PM
beastin91rs
10-09-2015 08:38 AM
Dialed_In
08-20-2015 02:45 PM
Quick Reply: dual exhaust and body squeaks fix
