Pulling out the SMOG Crap!!
#51
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
It depends on where you are if they check for the cat and other emissions equipment.
#52
Car: '86 Transmaro
That's why many people hollow out their cat and run it like a straight pipe. Though it still looks like a cat is there.
#53
Car: 91 z28
Engine: 5.0
Transmission: 700r
smog pump delete problems
removed all smog or air pump pieces. now its sluggish no power and looses throttle response then throws a code. dont know the code dont have a reader and dont think it will make it to the parts store. 91 z28 5.0 700r. all stock. if i get a performance chip will this help.
#54
1 Post
Car: 1989 Firebird Formula
Engine: 385
Transmission: Full Manual TH350
Axle/Gears: Moser 9" 3.70
Re: smog pump delete problems
Note that I run MAF (1989), and I had no problems or lost performance from removing my AIR, timeslips to verify. MAP on the other hand (1990 and up IIRC) I've heard it causes issues and lost performance.
#55
Car: 91 z28
Engine: 5.0
Transmission: 700r
Re: Pulling out the SMOG Crap!!
I got code 43 put a resistor on the knock sensor wire then to ground no help. Starting touching everything. Only had it 4 months got to the distributor and found it was loose and retarded along way. Adjusted the timing and tightened the bolt runs great. Do i still need to prodram the ECM? Thanks for the help.
#56
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
I have no idea why Koon brought this one back up from the dead...
-- Joe
#57
Car: 91 z28
Engine: 5.0
Transmission: 700r
Well its bc i couldnt figure out how to start a thread i could only add to them so i figured give it a shot. There is a ton of them with no solution. So i posted where i could and hope for some help.
#59
Car: 91 z28
Engine: 5.0
Transmission: 700r
Pump came apart. We have no emmissions so less stuff to look at under the hood. And bc i wanted too.
#60
Car: 82 z28
Engine: 305,eldelbrock cam and lifters, per
Transmission: auto
Axle/Gears: 352
maybe he better get a honda and leave the big boys alone, i bet my emission legal 82 z28 would spit **** on anything he could build,,,,,,,,,,,,,,,,,,,,,
#61
1 Post
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
If your knowledge comes from automotive magazines, than I guess that explains your ignorance.
When you've owned a race shop for as long as I have, worked in dealerships, built dozens of motors, read as much sae documents as you can take, do your own dfi tuning, etc _THEN_ you can tell me i'm wrong.
And btw, my original statement was: "And sometimes the added backpressure of a cat can actually increase the performance of an engine." Which has been proven in the "magazines" as well. I don't think I ever said to use stock manifolds instead of headers, etc. But you decided to go off and list all the things that would absolutely positively be a negative restriction. Fine, if thats how you argue points than whatever.
But since your our new in house automotive expert, I'll back off now. Do you have a column in super chevy?
-- Joe
-- Joe
