Hedman Longtubes + AFR angle plug heads???
Car: '85 Z28
Transmission: WC T5, 3.23 posi
Will Hedman longtubes work with AFR angle plug heads? I looked at Summit and it said they would fit angle plug heads, but I didn't know if AFR's have a different angle than the L98 heads or something. Is there anybody that has this combo? BTW, the heads are AFR 190's if that matters.
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Just so you have more info on it, AFR has 3 types of heads. Straight, angle, and L98 angle.
Just wanted to throw that out there.
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
Go to Hedmans website... lookup the headers you have and they have NOTES on them... what fits what doesn't, legal not, etc.
That's how I know my Hedman Shorties will be fine with my Pro Topline Angle Plugs.
i have a 91 w/ a 305. do Hedman longtubes go in with any trouble? I don't really car about ground clearance, just wanted to know if i have to dent the primaries or chop up or jack up anything to get em in. thanks --matt
Car: '85 Z28
If you have an auto they should fit fine, but if you have a T5 you will need to bend the collector down to clear to slave cylinder.
I've heard on the drivers side the collector can hit the K member. Might have to do some grinding
evilstuie
02-28-2016 03:33 PM
