Manifold Bolt Fell into headers?? Help
Old 06-12-2003 | 08:59 PM
Blackv6FBird's Avatar
I took my 89 firebird to the shop the other day to get my exhaust fixed, i dont exactly know a lot about cars but i have close friends who do... but none know how to do this... the guy at the shop told me that my car has lost a lot of power due to a bolt that broke off and fell into the headers. He said its easily fixed, but he didnt tell me how to do it.. could someone tell me how to get the bolt out of my headers and how to restore the lost power.
Old 06-12-2003 | 09:06 PM
Ryknow86's Avatar
Car: 84 Camaro Z28
Engine: carbed 350
not sure if this would work but you could give it a rip. put a pressure washer in the end of it and blast it out the way it fell in, force it back out where it came from.
Old 06-12-2003 | 09:19 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
How would a bolt break off and fall into the headers with the headers on? Where did the bolt come from?
Old 06-12-2003 | 09:27 PM
The guy told me the bolt broke off of the manifold and into the headers
Old 06-13-2003 | 01:16 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
if there really is a bolt in there, just leave it. It wont do any harm. I had a transmission bell housing bolt in the passenger side of te y-pipe for the longest time.
Old 06-13-2003 | 02:10 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
I'm not 100% sure here, but it sounds as though this shop is trying to take you for a ride. I am still trying to figure out how the bolt got in the header, mind you it would go right down to your cat. Loss of power?? Not from a bolt falling into your header anyway. How did this shop come to find this bolt in the header also?? If they seen it in there, they could have taken it out. Unless they are hearing a rattleing around the cat, Then it is most likely that the Cat is shot and plugged up , hence loss of power, and a rattleing noise too.
We need more info as to how the shop came to this conclusion?? Were they working on it and it fell in there then? If so they are responsable to remove it. No bolts are anywhere that they can just fall into the header if they where not off.
Old 06-13-2003 | 02:17 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
im with Kaz on this one, i think that shop is bsing you.
Old 06-13-2003 | 07:10 PM
Well all I know is that the guy was reaplacing the pipe that goes into the cat converter and when they were done when i went to go pick up the car from the shop thats what he told me..... but the car already for bout a month or so has been weak like that but i know its not sdposed to be that weak..
Old 06-13-2003 | 07:11 PM
Well all I know is that the guy was reaplacing the pipe that goes into the cat converter and when they were done when i went to go pick up the car from the shop thats what he told me..... but the car already for bout a month or so has been weak like that but i know its not suposed to be that weak..
Old 06-13-2003 | 07:18 PM
my car
Reddeath210
10-06-2015 08:20 AM
theurge
08-21-2015 12:46 PM
Dialed_In
08-20-2015 01:45 PM
mustangman65_79
08-07-2015 09:55 PM
Quick Reply: Manifold Bolt Fell into headers?? Help
