Is 3" exhaust too big?
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
Hi All,
I am trying to figure out what I am doing for my exhaust system for my LS1 thirdgen.
The 2001 engine is stock with the exception of cam, springs, and pushrods. No head porting yet, headers or power adders.
Unfurtunltely, I need to run cats. I was considering 3" pipe, cats, etc. from the engine all the way back. Is this overkill for this setup? Since I can not run headers, I was hoping to make up for some of the restriction on the back side.
All thoughts appreciated.
BILL
BILL
Car: 1991 Trans Am
3 inch is not too big for an LS1. in fact its on the smaller side of LS1 exhausts. some people are running 4 inch setups on stock motors and not losing any power...:hail:
I dont think it will be too big. Why dont you just get the mufflex y pipe and catback. On my heads/cam LS1 with bolt ons I am running PPC headers, which are the grot design, with a 3 inch y pipe into a 3.5 inch single exhaust back to a crossflow muffler with dual 3 inch outlets. I will be getting dual 3 inch cutouts soon as well.
Originally posted by wm_sorg
Sounds like a great setup. Do you have pictures?
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Originally posted by 89gta383
Import guys run 3" exhaust. That's on a 4 banger. Run at least 3".
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
Go with the 3" at least. Anything smaller would almost be choking the engine.
Originally posted by 25THRSS
I will have pictures within the next couple weeks. I actually don't have the y pipe yet because the owner of PPC is still working out the bugs, but it should be ready very soon he says. I'll send you some pics of the headers as soon as I get some.
Back to the topic, on my 01" SS I'm running the PPC LT's as mentioned above with a 3" "Y" with metallic cats into a Corsa 3" cat back. 3" is by no means too big unless you're talking about ground clearance issues. Mine is lowered 1.5" so I defintely didn't want to go any bigger. Hope this helps
Car: 91 Z28
Engine: Forged 383
Transmission: Pro-built 700R4
Originally posted by Z28*****
Import guys also run 6" exhaust tips, does this mean we should all get at least 6" tips ?
Thanks for the pictures. I will go with 3" if I can clear it. Otherwise I will go 2.75 or 2.5 until I get past the tail shaft and go 3" out to the back.
Thanks to all who have posted.
