Edelbrock RPM Series VS. Hooker Aero Chamber
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
What is the difference between the Edelbrock RPM Series and the Hooker Aero Chamber??
RPM Series Muffler:
Hooker Aero Chamber Muffler:
1989 Iroc-Z 5.7 350, Blue, T-Tops
Lightly Moded:
Edelbrock Headers, Rebuilt B&M 700R-4 Tranny, Higher Stall Torque Converter, Airfoil, 3.4 w\posi, K&N's, Ported Plenum
-- Blue LED Bakelite Dash & Climate Control
"Just some 17 Year old spending every dollar I make on my car."
[This message has been edited by 89 Iroc Z (edited October 06, 2001).]
RPM Series Muffler:
Lightly Moded:
Car: 1989 IROC-Z
Engine: 350 Vortech Supercharged ZZ4 TPI
The internal baffles/baffling is different. As a result, each will flow differently producing different power as well as different sound and tone.
1989 Chevrolet Camaro IROC-Z
L98 - 350c.i. TPI, rebuilt 700R4 auto w/shift kit, Dual catalyst Monza PaceSetter Cat-Back, SLP 1 5/8 Coated Headers, 3.23 Posi rear, Hypertech Thermomaster chip with 160stat, MSD 6A, March Under-Drive pulleys, AFPR, K&N's, !Air Box w/ Ram Air, moddified MAF, !TB Coolant, Spohn Dual Cat SubFrame Connectors, Alarm, Keyless entry, remote starter, 92 Z28 AeroWing, Brand New Paint (6/21/01)
Future: ZZ4 TPI w/EGR, T56, 3.42 or 3.73, Spohn strut tower brace and LCA's, Accell Universal 24# injectors
1989 Chevrolet Celebrity Eurosport <--DEAD AS OF 9/20/01
2.8 MPFI, no mods
225,000 miles and still ticking!
More info and pics on my webpage:http://go.to/iroc-z
AOL IMer: GPA 0point0
2.8 MPFI, no mods
You cant get a 3" inlet cross flow Hooker without getting it as part of the catback.
-Tas
'89 Formula WS-6
305, TBI, 700R4, P.A.W. 14x3 open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips, Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248)
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Got Beach?
-Tas
'89 Formula WS-6
Super GRK_Taz World
F-Body Dual Exaust
AOL IM: superGRtaz
Got Beach?
It might be something to look into but I have heard rumers about the edelbrock mufflers. I have heard the mustang guys that have tried these mufflers say the internals come apart in the Edelbrock. I don't know how true this is but it could be a factor in your desicion.
Car: 99 Formula
Axle/Gears: 342
There are sound clips of the Hooker in a recent post. I have it and sounds awesome.
"Rice burners are like tampons...Every pu$$y has to have one"
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
'86 IROC
GM GOODWRENCH 350
KN AIRFILTER
160* Stat
3:73 Posi
Rebuilt 700R4
Car: 1989 Iroc-Z
Does anyone have a sound clip of the Edelbrock RPM Series on a camaro?
I was just fixxing to post and ask about this.My wife's car has a Hooker Aero Chamber on it right now but it is starting to get acouple of holes in it.I've been debating on putting something different back on it.Namely an Edelbrock RPM series.Anyone know which is the better choice.I'm having a hard time 'cause the Hooker sounds pretty sweet.I may just get another one of those.
Wife's car:
90 CamaroRS with an 88TPI 350,'87IROC disc rear end,Dynomax Superflow cat,3"piping from cat to Hooker Aero Chamber muffler,K&N drop ins,KYB shocks&struts
My car:
89 Mazda Rx-7 with many mods.
[This message has been edited by Dak (edited October 10, 2001).]
Wife's car:
My car:
Car: 1982 Camaro Z28
Engine: Self-built 350
Transmission: Pro-Built 700r4 w/2800 Vigilante
Axle/Gears: Eaton 3.73 w/Moser axles
I've got the Edelbrock RPM series on my 82 Z28 with stock manifolds and cat. It sounds decent at idle, but sounds sweet at of above 2500 RPM.
--Matt K
1982 Camaro Z28 5.0L 305
65000 Orig. Miles
Edelbrock RPM Series Cat-Back Exhaust
New Rochester Quadra-Jet Carb
New Water Pump & Belts
Hi Performance 8mm wires
Bosch Platinum Plugs
Hella Fog Lights
Coming soon (hopefully):
SLP Headers
Hi-Flow Cat
16" Polished IROC Wheels
Edelbrock Performer RPM Intake
Crane Cams Hi-Output Ignition Coil
My Camaro
--Matt K
65000 Orig. Miles
Hella Fog Lights
SLP Headers
Hi-Flow Cat
My Camaro
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
If I where you I wound go with the edelbrock or the flowmaster, 2 diffrent sound ing systems but both sound great. I think the hooker system is for older muscle cars, it just has that sound to it.
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Hotrodboba400
12-10-2019 08:07 PM
