why do you have to plug the A.I.R. system? (no cat)
Car: RS
Transmission: 4L60
I replaced my pipe with a cat a couple of weeks ago and never plugged the A.I.R. is this hurting anything? Every once in a while I get code 32, but I doubt plugging the air will get rid of that.
late model 91 rs, fully loaded, auto, t-tops, red leather, paint- gm red and yellow blend (light red), custom painted 16" Camaro rims
305 tbi flat base 14"x3" with K&N, hypertech chip, accel super stock plug wires, only use full synthetic oil and delco filter, 2 1/2" cat delete pipe, Edelbrock 3" cat-back
MTX sub and amp, Bose all around
vic_v8@yahoo.com
street kills: New v-6 stang, 96 v6 camaro, totally killed '86 SC Camaro (305), 91 z 28 with 305
15.854@87.57 (I think I could have it 15.5 with good tires and two more runs)
next month: rest of ultimate tbi
vic_v8@yahoo.com
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
when you say that you "replaced your pipe with a cat" do you mean that you replaced your cat with a pipe?
hopefully you do, so i will go with that...
i dont think you will hurt anything, but you will have an exhaust leak for sure. unless you have headers that dont have AIR tubes, you will.
the AIR system has nothing to do with the computer as far as throwing codes. the EGR code that you are getting may or may not be a side effect though...i dont know, but i am sure somebody here does. i doubt it though. i dont have AIR or a cat or EGR or any emissions for that matter on my car and i haven't had en EGR code since i actualy had EGR.
-Brian
1991 Camaro RS
GMPP 350 HO crate engine - 454 TBI, MSD ignition, SLP exhaust, everything is new
700R4 - 2,400 stall converter, vette servo, shift kit
My car's webpage - z28boy.cz28.com
President - Central New York F-Body Association
Email - z28boy@twcny.rr.com
AIM - "Z28 Boy"
-Brian
1991 Camaro RS
AIM - "Z28 Boy"
1 Post
Car: 99 Formula
Axle/Gears: 342
He's probably saying that he had a straight pipe but put a cat in it's place, that has the A.I.R hookup, I know I just had a cat welded on and the exhaust shop welded the tube closed.
"Rice burners are like tampons...Every pu$$y has to have one"
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
'86 IROC
GM GOODWRENCH 350
KN AIRFILTER
3:73 Posi
Rebuilt 700R4
Car: RS
Transmission: 4L60
I meant to say I had a cat then removed it and put on a straight pipe. sorry I was in a hurry to get to school.
vic_v8@yahoo.com
vic_v8@yahoo.com
