anyone know how to run true duels on third gen?
i went to the muffler shop the other day and they told me that i couldnt run true duels with cut offs. they said the flowmasters would scrape. anyone know if i actually can anyhow? would like to know. thanks
We'uns got a new-fangled thingy on this-here board...it's called a "search" button. You might wanna check it out...
Yes, it is possible, but it cuts your clearance somewhat, depending on the diameter of your pipes, how you route them, size of the mufflers, etc...and it is quite difficult to get a shop to route them over the rear axle.
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Not to bust on you a lot but do a search...
Willie has the nicest true DUAL system I've seen..even has a H-pipe...and he posted pics.
Ed
Ed
Car: 1987 Z28 Convertible
Transmission: 5-speed
Thanks Ed. Here's the second of two threads:
https://www.thirdgen.org/techbb2/sho...hreadid=145673
You can also click on "SC Z!!!" in my sig, then Exhaust.
Car: 82 Pace car
Engine: Small block
Transmission: TH350
Jesu take it easy on teh guy he's got 3 f'in posts. Srry man sometime these guys get pissy. hope that pic helps it was posted about a month ago and the Track bar is Granatelli not Comp. Eng.
that exhaust is nice but not what i had in mind. i was wanting it with turn downs infront of the axle and was wondering if anyone has done it without getting bigger rims. the exhaust i have now is 3in coming from hooker super comp headers to a single 3 1/2 in pipe under the body over rear axle to my flowmaster, but i want what is described above, curious if it could be done with 3in. pipe to two 40 series flowmasters with turndowns. without bigger rims ofcourse.
Car: 1987 IROC-Z28
Engine: 383 Vortec - carb
Transmission: T56 - 6speed
Car: 1986 Camaro Z28
Engine: 305 lG4
I have seen the headers to mufflers to turndowns thing done before and it worked out just fine. The only problem is there is no way to put two flowmaster 40 series mufflers under your car without losing some serious ground clearance. I would suggest using a 4" round muffler such as a dynomax bullet instead, that way you could still go up drive ways.
z28redline
z28redline
1 Post
Car: 99 Formula
Axle/Gears: 342
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
Originally posted by StreetRCR
Like this??????
Like this??????
Hey StreetRCR is that your car? Where Is that cross bar from Competition Engineering, or is it just a sticker on there? I would like to see more pics of that If You have any.
Terrell351
06-13-2021 01:13 PM
CarGuyDennis
137
12-06-2016 11:02 PM
1992 Trans Am
08-08-2015 08:16 PM
