woundering will i pass the sniffer
i have an 82 z28 and it has a rebuilt 305 and a th350 tranny and the engine has the computer and emmission delete package and all i have it the old pancake cat. that is goin to be replaced very soon with a catco hi-flow cat and the hook cat-back and i already leaned out the carb with leaner metering rods and a different hanger. after i get the new cat does any one think i will pass new jersey emmissions. also i have heard that if i put some dry gas in like 10 bottles my car will run cleaner to is this true becuz i want to pass with flying colors. please let me know thanx
Car: 1986 Firebird
Engine: 2.8 V6
If you don't think you'll pass the sniffer, take a shower; it's cheap insurance against your date leaving early.
Oops; wrong website!
[edit] Oh, hey, you're in NJ? I passed emissions with a few "cheap" tricks... I put a new air filter on from K-mart. I cleaned up the inside of the distributor cap from carbon. I checked the gap of the spark plugs. I checked the timing after yanking my aftermarket chip. It was January, so I put a piece of cardboard over my radiator to help the car run hotter. The day before the test, I put a bottle of "Guaranteed to Pass" (G2P), from Pep Boys, in my gas tank, and ran the tank down to almost empty. I filled the tank, went for emissions, and passed w/flying colors.
Basically as long as your car is in tune you should pass. One misfiring cylinder can cause 10 cars worth of pollution! Putting a fresh air filter on will help you pass the CO stat, and might also help you pass the HC stat. (Dirty air filter = rich = high HC & CO. Lean condition = high HC only.)
[This message has been edited by TomP (edited August 30, 2001).]
where u from tomP and well right now i leaned out the carb and im gettin my new exuast put on soon so i can get it inspected and with the new exuast is a new high flow cat from catco and if i use that g2p stuff and sum dry gas ya think id pass good. i think i might . thanx
I managed to pass with my car with a hollowed cat and no air/ emissions controls.
86 Iroc, 383 Ported and polished Sportsman II, stock ported TPI, #24 svo, custom chip, Slp 1 3/4 and 3" Flowmaster, Serpentine with Hypertech Pulleys, Comp Cams roller 218 224, 10" 2600 stall, Stage 3 Pro-Built 700R4 Last year 12.969@106.54 1.991 60'
87 K30 Chevy P/U 355 TPI Crane Compucam, Ported heads TH400, Hooker headers and edelbrock mufflers (LOUD)no cats, 8" lift, 36" super swampers, 4.10 detroit lockers,
darwinprice
17
10-11-2015 11:51 PM
