Install headers, what do i do about plug wires, HELP!
Car: 2002 Z28
Im installing headers this weekend, and i need help rerouting the plug wires so that they dont burn up, what do i do, what do i buy.
THANKS
1990 RS TBI
THANKS
1990 RS TBI
Car: 2002 Z28
will the Made For You center bolt looms fit on my LO3, i really need help, headers going on in 2 days.
I think Im using those, I can't remember..lol.. if they are 45 bucks from summit, thats what I have. Depending on what headers you have, you will probably need some new heat resistant wrap for your wires. I bought six boot covers for like 40 bucks, they did the job nicely.
Location: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
You NEED 90 degree spark plug wires. Clearance between the plug and header will be tight (about 1/4 inch) but shouldn't cause any problems. Coated headers helps.
You can get wire looms for that dress-up look.
But some well placed tie-wraps will do the trick too.
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Z28 Grille w/aftmkt fog lamps, MacEwen white-face guages
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, 3.42 gears w/Torsen posi
Performance:
Electronics:
Car: 91 RS Convertible
Engine: 305 TBI
There are several routes you can go.
Here are some of the options I found.
Starting with Jegs.....
MSD # 121-3408 $9.99
Heat guard sleeving,does complete V8 set of wires. offer heat protection and allows cool air to pass though which also prevents moisture build up.
Spectre # 865-9002A $12.99
Braided hose in red,blue and white/silver. Protects up to 1400°F and fits 7-9mm plug wires. Comes in a 10 foot roll. Champbands are needed to complete look/installation. (could not find a part #)
Going with Summit.....
Taylor (no part # given in catalog)
See page 125 of new catalog. $ 48.95
Taylor 8mm Braided Ignition wire set.
All the work is already done for you.
Accel # ACC-8008B $42.95
Braided ignition wire set w/90° boots. Can withstand high heat and have 8mm wires.
Taylor plug boots # TAY-2560 $52.95 for a set of 8.
Comes in 6 different colors.
Made for you wire looms for center bolt valve covers.
# MFY-5035611 $41.69 for a set.
Offers 6 different colors.
Well, that should give you enough to make a decision as to what you want and what your budget can afford.
Let us know which route you decide to go and how it worked out for you.
I'm interested in hearing the results.
You don't need 90 degree boots, in some situations it doesn't really help. You can't know the clearance without knowing what type of headers he is installing, they are not all the same. I would urge against using tie wraps, they look pretty trashy and you can't use the cheap plastic ones because they will melt.
I would go with the braided hose from spectre, it seems to be the cheapest and most wrap is only 1000-1200 degrees. 10 feet is also going to last you a long time, you will only need to wrap a small part of the wire.
Car: 2002 Z28
sorry i didnt put the make, they are Edelbrock TES headers for a TPI engine, but they are going on my TBI.
1992 Trans Am
05-10-2023 07:19 PM
eightsixseven
08-14-2015 03:09 PM
Zachattack0925
08-12-2015 09:52 PM
