Anyone with Hooker LTs (2210) and "L98 Angle Plug" heads?
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Just trying to see if I will run into a problem with regard to fitment. I have AFR190 heads with the L98 Angle Plug which is totally different than the standard angle plug. These heads work great with SLP headers but I just wanted to see if anyone is running the L98 Angle Plug with the Hooker SuperComp Long Tubes (2210).
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Tim
https://www.thirdgen.org/messgboard/...ML/007318.html
Steve was having some spark plug issues with this combo. I don't know if he resolved it yet or not.
1 Post
Car: 1987 IROC Z28
Engine: 6.0L LQ9 crate engine
Transmission: Performa Built 700R4
Axle/Gears: 3.42 10 bolt, Eaton/Moser
Trax,
I found a website (see below) that listed the Hooker SC LT (Model 2210) headers and some application footnotes. One of the footnotes (#62) for model 2210 was that it WILL work with angle plug heads. Not sure if they mean ALL angle plug heads, but here is the URL:
www.martelbros.com/hooker/9.htm
My AFR 190s are straight plug heads.
Good luck!!
Phil87IROC
Blue '87 IROC, 383 Crate Motor, KB pistons, AFR 190 heads, ZZ-9 cam, Edelbrock RPM intake, Hooker SC/LT headers, Edelbrock 750 cfm Carb (#1411), stock T-5, GM 3.42 rear w/Auburn posi.
Ohio Valley Dragstrip Trophy Bracket WINNER - 8.39 ET on a 1.82 sec. - 60'. Best MPH = 84.44. Still Tuning Carb!
Red '89 IROC L98, 700R4, T-Tops, K&Ns w/open air boxes, 160 T-stat, Hyper Chip, gutted MAF, 53kv coil, MSD wires.
[This message has been edited by Phil87IROC (edited April 29, 2001).]
Good luck!!
Phil87IROC
1 Post
Car: 1987 IROC Z28
406,
I am in the process of installing my 383 back into the car. I have the Hooker 2210s ready to install. I have no y-pipe yet. I am shopping for one or considering having the muffler shop build me one. What do suggest?
I heard the Mufflex y-pipe is pretty good. I may race the car with straight headres! :-)
Thanks!
Thanks!
Well, I just installed the Mufflex y-pipe. I had to do alittle custom cutting and denting in the right places but I finally got it all to fit togther correctly on the car. For what it's worth, if you can find a local muffler shop to do it for you, I would probably go that route...of coarse, this is after spending several hours on my back wrestling around with it
An old subject back from the dead ....
Has anyone else installed Hooker SuperComp long tube headers on a motor with L98 Angle Plug heads? This includes any of the ZZ crate motors, corvette style aluminum heads, L98 style AFRs, or the Edelbrock centerbolts for TPI F-bodies. I'm getting ready to install my long tubes in the next couple of months and I'm just trying to see if I'm going to run into spark plug clearance problems.
Tim
Tim
hey trax...i dont know the difference between l98 angle plug and other angle plug. but i have had more problems doing my motor than i car to write down in one sitting! but....my brodix track 1's and the hooker super comps fit well together and with plenty of room to spare. on a second note...
i tried slp shorties (1 3/4) and could not fit the plugs in even dimpling the headers...but others on here use the l98 heads and slp's (so this leads me to believe l98 and brodix angles are different) SO THIS TYPING WAS A WASTE OF TIME!! but anyway.... after i get my oil pan back from the welder...later on today....i will put it in...because the damn oil line comin out of the pan was in the way of the header...but i think i am unique with this problem!!
HAVE A NICE DAY
87 z28 bowtie aluminum 420small block dry sump crower lt. wt. knife edged crank oliver lt wt rods brodix track 1's super ram intake slp 1 3/4 headers accel dfi art carr 700 r4 3.42 gears ssm sub frame/ladder bars.....other parts on the way ,soon to be finished!! couple more weeks!!!
http://people.ne.mediaone.net/gdm
HAVE A NICE DAY
1 Post
Car: 1987 IROC Z28
I just completed my 2210 install on AFR 190 STRAIGHT Plug heads. Only had trouble with one plug, #7.
If you do have a plug fitment problem I have an answer for you!! MAKE YOUR OWN SHORTY PLUGS!!
I did for my plug #7. I used an AC Delco FR3LS plug and modified it to fit perfectly. Car runs strong!!
Check out:
http://www.geocities.com/cfrios/Phil...l?996948051310
Email me for more details if you like.....
Phil87IROC
Blue '87 IROC, 383 Crate Motor, KB pistons, AFR 190 heads, TPIS ZZ-9 cam, Edelbrock RPM intake, 1" TD spacer, Hooker SC/LT headers w/ Mufflex Y-pipe, Edelbrock 750 cfm Carb (#1411), Stock T-5, GM 3.42 gears w/Auburn posi.
Ohio Valley Dragstrip (KY) Trophy Bracket WINNER - 8.39 ET on a 1.82 sec. - 60'. Best MPH = 84.44. Still Tuning Carb!
Red '89 IROC L98, TES w/Flowmaster, 1LE DS, 700R4, T-Tops, K&Ns w/open air boxes, 160 T-stat, Hypertech Chip, gutted MAF & CAT, Jacobs Ign., 53kv coil, MSD wires.
[This message has been edited by Phil87IROC (edited August 22, 2001).]
Check out:
Phil87IROC
no pics of headers in. you are talking the slps right? i wont be putting them back in either. thurs or friday i will be picking up my hookers (from the corner of 5th and main...hahhahahaa) actually from being coated and i can take a couple pics of those if youd like
Actually I was talking about the Hookers. I must have misunderstood your earlier message. But yes I would really appreciate some pics when you get them installed.
Back from the dead again. Hooker Super Comp Long Tube headers work GREAT with L98 angle plug heads. No interference problems at all.
Pics are huge. Broadband recommended.
http://www.celligent.com/tim/iroc/progress/DCP_0833.JPG
http://www.celligent.com/tim/iroc/progress/DCP_0834.JPG
Tim
Tim
1 Post
Car: 99 Formula
Axle/Gears: 342
Looks really good. I just got new heads, but didn't get angled ones, because I may use Hedman LTs. anyone know if these will work? if I had gotten angled plug heads?
Car: Faster
Engine: Than
Transmission: You!
My Coated 2210's worked great with the stock "non-angle" plugged L98 Heads. Any angle period will only be an improvement of spark plug and plug wire boot clearance! Dont worry, it WILL work better than non-angle plug heads.
To people like me, with Vortec heads and Hooker LT 2210's -
I dont know what is different about plug location on the Vortec heads vs. L98 heads, but the #7 primary is ALOT closer to the spark plug on the vortec heads. I'm going to have to dimple the #7 primary to allow a spark plug boot to fit onto the plug. (Tip of plug is 1/8 of an inch from primary) causing plug wire not able to be put on. On the bright side, dimpling the header primary slightly in that location will easily correct this issue.
The exhaust shop had to do a little custom fitting and dimpling on the mufflex y-pipe on my exhaust setup (but that is the case because I'm running a T-56 and SPD x-member.) Your results may vary. Just my $.02
Good luck Trax!
Mike (1bad91Z)
Good luck Trax!
Mike (1bad91Z)
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Mike,
Slightly off topic...... So the 2210s work out with the T56 alright? Any pics or descriptions of the clearance for the slave? I have the Spohn CM..... I am thinking of a custom Y-pipe instead of the Mufflex one as well.......
Thanks,
Matt
Thanks,
Matt
Car: Faster
Engine: Than
Transmission: You!
The headers work fine with the T-56, no clearance issues at all! The slave has plenty of room. It's the y-pipe that you WILL have issue's with!
Mike (1bad91Z)
Mike (1bad91Z)
92projectcamaro
01-18-2016 08:00 AM
New2Chevy
09-28-2015 12:35 AM
