Off Road H Pipe??
Off Road H Pipe??
Is there any way to get the Exhaust Shops to Put an Off Road H Pipe on my 89 T/A without them getting their panties in a Wad????? What if I told them I was building an All out Track Car???
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
3rd gens would have to be true dual exhaust to need an 'H' pipe
The mind is like a parachute, it only works when its open
you need an off road y pipe. do you have a dual cat set up. its not hard to do cut off the cats and get to pieces of pipe the same lenght. Make sure the inside diameter of the new pipe is the same size as the outside diameter of the y-pipe. at least you can clamp them this way till you find someone to weld it
91 Z28 slp headers adj reg accell cap rotor coil comp cam roller
random tech cats flowmaster catback
