Header Gaskets
Car: 1989 IROC-Z
Engine: 350 Vortech Supercharged ZZ4 TPI
Header Gaskets
I was told by the man that is going to install my headers that the gaskets that coem with the headers to install them are no good. he said that the gaskets they give you will start to leak rather quickly.
I ordered SLP headers... are the gaskets they give no good? If not, thats fine - but which should I get?
Also, exactly which gaskets am I gonna need to install SLP 1 5/8 headers and the SLP Y pipe on a dual cat car? I am most likely going to order gaskets from Jeg's. What size do I order to go with my SLP 1 5/8 jet coated headers and going onto my stock L98 heads? Which locking bolts should I order?
***The driver formerly known as 89IROCZ***
1989 Chevrolet Camaro IROC-Z
350c.i. TPI, rebuilt 700R4 auto w/shift kit, Dual catalyst Monza PaceSetter Cat-Back (currently no muffler, sounds on webpage), SLP 1 5/8 Coated Headers on order, 3.23 Posi rear, Hypertech chip with 160stat, Under-Drive pulleys, AFPR, K&N's, !Air Box w/ Ram Air, moddified MAF, throttle body coolant bypass, Spohn SFC's on order, Alarm, Keyless entry, remote starter, 92 Z28 AeroWing, Brand New Paint (6/21/01)
Future: ZZ4 TPI w/EGR, T56, 3.42 or 3.73, Spohn strut tower brace and LCA's
1989 Chevrolet Celebrity Eurosport
2.8 MPFI, no mods
225,000 miles and still ticking!
More info, pictures and sounds (of the IROC) available on my webpage: http://go.to/iroc-z
AOL IMer: GPA 0point0
[This message has been edited by L98IROCZ89 (edited July 24, 2001).]
2.8 MPFI, no mods
Within a week my gaskets on my SLP headers leaked like crazy on one side but not the other. I went with felpro and it solved the problem untill I cracked a head, then after replacing the heads I went with the SCE copper gaskets and have not had ANY problems. They are probably overkill for street but they hold up real well.
My SLP gaskets havent leaked yet,only been like 3 weeks though, but pretty good considering the two end flanges aren't even flat on the driver's side...
90 IROC 5.7l (L98)
ram air, K&N's, air foil, full exhaust
LIKE A ROC
http://members.nbci.com/IrocZgarage/home.htm
90 IROC 5.7l (L98)
LIKE A ROC
Chad Speier
09-24-2015 12:32 PM
