What headers for a duel exhaust setup?
OK I am gonna do a true duel exhaust setup, just headers to pipes to the mufflers dumped right in front of the axle. I want the headers smog legal however. which ones do i want? who else makes smog legal headers for our cars besides Edlebrock TES and SLP?
check my site. You can use Hookers, SLP, or Edelbrocks. I think Kevin L. said he had soem SLPs without the Y pipe. That would be perfect for you. go ask him on www.sc3gfb.org . You will need a Y pipe and cat in the stock place to pass smog though.
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
To be installed eventually far far far into the future: Yours if the price is right and I don't have to ship :
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
-Tas
'89 Formula WS-6
Super GRK_Taz World
F-Body Dual Exaust
AOL IM: superGRtaz
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
"True duals" and "smog legal" are practically mutually exclusive. You can do shorties with A.I.R. & O2 fittings, but if you then take them straight to the mufflers with no cat in the factory position, you are NOT smog legal! So, what exactly are you trying to achieve?
The Hooker 2055's (as opposed to the 2460's) have a y-pipe that allows you to put a 3" slip-fit cat in the factory positon and keep it entirely smog legal. What you do after the cat is up to you. Similar results could be accomplished with TES, Hedman, SLP, Dynomax, etc. Or, you could get a dual-cat system from TES or SLP, and put your duals after them. But, to retain "smog legal", you'll need a y-pipe to the cat(s).
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Ok, what I meant was smog legal headers. I know the rest of it wont be but I want the headers to be so that I can swap on the stock setup to pass inspections.
And after some looking....those cheaper hooker's will do just fine, they come with a location for the O2 sensor and AIR fittings.
you are in CA. If you don't have the E.O. tag that makes them smog legal, THEN THEY AREN'T smog legal. The cheap ones will not let you pass even with a Y pipe cat air and all that crap without that E.O. tag.
-Tas
-Tas
must suck to live in calli!!!
84 Z28
78,000 miles
1970 350 ci 4 bolt chevy motor punched .030 over to a 355
stock 1970 heads with 1.94's and very mild porting
edelbrock rpm cam,intake, 750 4barrel
weisco 9.6/1 pistons & rings
edelbrock headers and catback (without the cat)
700r4 trans
3.23 rear (no posi yet)
84 Z28
78,000 miles
700r4 trans
downsouthboy
08-29-2015 11:29 AM
