What do you think of Catco converters?
Car: 88 IROC-Z (Sold)
Engine: 5.7L
I have found two different cats that are what I am looking for, but are seperated by $100. One is a Catco from Summit and the other is a Random Tech (I think) from TPiS. Which is better and why? Just so you know, the Catco is cheaper at a little more than $110, while the Random Tech is over $200.
Matt
irocet@hotmail.com
drive.to/Stang_Kilr
88 IROC-Z -- 350 L-98, 700R4, Flowmaster, K&N, MAF Sceens Removed, Airfoil, March Pullies, Comp Cams Magnum 1.6 Roller Rockers, Bosch Platinum Plugs, Accel 8.8 mm Wires, Hypertech Cap & Coil, Hypertech Chip, Hotchkis Strut Tower Brace, One Loud Stereo!
Matt
irocet@hotmail.com
drive.to/Stang_Kilr
Well, in my case I've had my exhaust with and without the Catco converter. There was absolutely no sound or power difference with or without, and for under $100 - you can't beat that.
My car also "fast passed" the very strict Maryland emissions test with the converter. Most new Low Emissions Vehicles have trouble doing that!
1985 Z28, Jasper Class 1 350, Edelbrock Performer intake, Dual snorkel air cleaner, K&N, Edelbrock headers, Catco 3" cat, Hooker 3" cat-back, Richmond 3.73's, built 700r4 w/Darrell Young 2400 stall TC, JET Stage 2 chip, Hypertech coil, Lakewood LCA's, Powertrax locker, SSM subframes, Centerline Auto Drag's
I did a lot of info searching a few weeks back as I was replacing the cats in my car it came stock with dual cats. Random Tech would of cost me about $400 for two converters,but I ended up ordering two catco cats from Summit delivered to my door for around $130. They are 2.5 inlet and outlet which is a little bigger than my stock cats. Many guys on the board here use catcos I like them. If I really had a lot of work done to my motor I might of gotten the Random Techs but since your mods seem similar to mine I would get the catcos and with the money you save put it towards a new Torque Converter or something. If you are using only one converter get the Catco Hi Flows check out www.discountconverter.com they are a little bigger. I wanted to get them but I could not fit them under my car side to side.
SLP 1 5/8 Headers,ATR catback exhaust,SLP cold air box,Crane 1:6 roller rockers,Bosch plugs and MSD wires,MSD Coil,Fastchip,Borg Warner 9 bolt 3:27,Corvette Servo,ROH ZS 17X9.5 Goodyear GSC,s 275/40/17
Engine: 5.7L
Thanks guys. I am going to order a 3" In/3" Out Catco from Summit here in a few minutes. I didn't figure that it could be a bad cat, since Summit is a pretty well respected company and I wouldn't expect them to sell crap. Anyway, thanks for your help.
Matt
irocet@hotmail.com
drive.to/Stang_Kilr
Matt
irocet@hotmail.com
drive.to/Stang_Kilr
Engine: 5.7L
Jza-
hahaha...I understand what you are saying, and I agree, but I was talking about quality parts specifically for our cars. You are very correct though about those things. lol
Matt
irocet@hotmail.com
drive.to/Stang_Kilr
Matt
irocet@hotmail.com
drive.to/Stang_Kilr
perfect for future striaght-piping. just put a 3" pipe through it.
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Soon to be installed:
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
-Tas
'89 Formula WS-6
Super GRK_Taz World
F-Body Dual Exaust
AOL IM: superGRtaz
The Catco converters are great, I love the one I installed on my car!
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Catco 3" High-Flow Catalytic Converter, Hooker 3" Aerochamber Cat-Back System, Transgo Shift Kit, Performance Resource Chip, Accel Ignition, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET: 14.32 @ 97.7mph
(corrected for elevation)
L98 TPI 350 (5.7L)
I just went through emissions yesterday and I surprisingly passed. When I got home I put in a replacement 3" straight pipe for my catco cat. I found that the insides of it were completely gone in only one year. Here in CT we have some pretty strict emissions but I still passed with basically no cat at all.
86 Iroc, 383 Ported and polished Sportsman II, stock ported TPI, #24 svo, custom chip, Slp 1 3/4, Comp Cams roller 218 224, 10" 2600 stall, Fairbanks 700r-4 W/superflow pro pump, 12.969@106.54 1.991 60', new times in spring
87 K30 Chevy P/U 355 TPI Crane Compucam, Ported heads TH400, Hooker headers and edelbrock mufflers (LOUD)no cats, 8" lift, 36" super swampers, 4.10 detroit lockers,
I LOVE my new cats...two pieces of 2 1/4 flex pipe from autozone .
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, Accel coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Accel 23# injectors, Holley AFPR, ported plenum,
Ruger P95DC, hot wife, new oil filter, thick rubber floormats.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
1990 IROC 350
Thirdgen89GTA
11-26-2015 11:04 PM
TMZIrocZ350
10-07-2015 12:09 PM
