Is there a decent 3" cat for about $100-150?
Got some grad money and I need a new cat and cat-back. I decided on the cat back already, but what's a decent cat that I can get for about $100-150? I need AIR.
Thanks!
Chuck Kulchar
1991 RS
Thanks!
Chuck Kulchar
1991 RS
Internet Racers Supply sells a 3"in/out "Mor-Flo cat" for $99.95. P/N MRF-94009
Jeg's sells a "DynoMax" 3" in/out converter for $129.95. P/N 289-15143
Racesearch.com sells "Random Tech" 3" in/out cats(don't know if they have AIR hookup) for $147.50. P/N's 813000 & 823000. They also sell the Random Tech catalytic installation kit for $16.95(P/N 516005).
All of the above are slip fit at both ends. This means you will need to have your y-pipe flanged to 3 3/8". You will also need to buy a clamp for each end. I will recommend band clamps over saddle clamps. Band clamps seal better and won't crimp the pipe(which would lead to no sealing).
JEG'S
Racesearch.com
JEG'S
Racesearch.com
Summit has a CATCO cat for around $100. However; make sure you get the correct one
and not a unversal fit. You made need a 3"
in & out with a two bolt flange on the out side, check your 3" pipe on you exhaust for
the proper conection. Yes they have A.I.R.
fittings.
fittings.
LT1Formula
10-08-2015 08:34 PM
