SLP Header Owners
1 Post
Car: 1989 Formula 350
Engine: 355 HSR
Transmission: Rossler 700R4
Axle/Gears: 9 bolt/3.27
SLP Header Owners
I just purchased SLP 1 5/8 headers w/o AIR and with JetHot coating. About 2 inches inside the second(from the front of the car) Exhaust port on the passenger side is a huge weld well over an 1/8 inch.Do they all come like this? How much of the weld can I grind out without weakening the weld?Here are two pics at http://24.22.209.39/badass4/header.html Thanks
89 formula 350, 73000k, 9-bolt 3.27, gutted MAF,dynomax muffler,gutted air box,kn,accel coil wires,dunlop 60/235
g-tech best(9 runs)14.48@101.1 0-60=5.91
track best(3 runs muncie,in 88 degrees)14.51@96.0 60' 2.089
in the garage waiting to go in are alum. L98 heads(bowl job by scoggins-dickey),ported plenum,ported high-flo edelbrock base ,SLP runners,Jethot coated SLP 1 5/8 headers,,zz3 cam 208/221 .474/510,1LE alum. driveshaft,TCI 2200 stall,LPE feul reg.,TPIS air foil,Flowmaster ForceII cat back,Gold crane 1.5 rollers,Eagle forged 5.7 rods,TRW Speed-Pro -21cc forged pistons,
[This message has been edited by L98FORM89 (edited May 12, 2001).]
Lovely weld... it must have been training day at SLP. I've noticed that their quality is not up to the hype that their marketing department says.
You can grind that out... leave a slight bump over the weld (don't grind into the pipes)
Hotrodboba400
12-10-2019 07:07 PM
84 TA NV
09-06-2015 08:02 PM
