Guys I have the sizes of the edelbrock gaskets, but there are no aftermarket ones.
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
If the edelbrock gaskets are 1.50 wide and about a 1 3/8 tall, I guess they are somwhat rounded on the bottom and the tops, what aftermarket gasket would work. Thanks This is what edelbrock told me.
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
If you havent tried looking in summit or jegs try that, they should have what your looking for.
1986 Trans Am
305 TPI
"If it's not one thing, it's another!"
http://www2.hanover.edu/hierlmeier
1986 Trans Am
305 TPI
Car: 85 TA
From what ive found they really dont make oval gaskets like you talking about for our cars. So I just got my edlrock tes headers and ordered percy's dead soft alumninum gaskets in the round stle...I hope these work well. thaats all I can tell you and good luck
88 IROC-Z 305 TPI 5 speed
Performance Resource Chip, Flowmaster American Thunder cat back exhaust, B&M Ripper shifter, MSD coil, TB bypass, TPIS MAT relocation kit , TPIS 170* t-stat, Richmond 3.73 gears, March Power & Amp pullies, Home made Ram Air, Steve Spohn SFC's, LCA's , Panhard bar, TPIS AFPR, Ported plenum by Daniel Burk, Gutted cat
Best et: 14.232
Best mph: 97.76
Best 60': 2.063
http://hometown.aol.com/famioso15/johnnyiroc.html
Best et: 14.232
Best mph: 97.76
Best 60': 2.063
when i had edelbrock on my ex-camaro, i used mr. gasket. it had an exhaust leak and cleaned it up w/no problems. took a whole 5 mins and sorta was a little past my headers but hey, there wasnt anymore "tick tick tick tick tick tick tick". = D
1990 G92 5spd LB9 - 3.42
Accel Ignition/Wires (8.8mm), Advanced Timing, Homemade Ram Air, TB Bypass, Ported and Gasket Matched Plenum, Synthetic Motor Oil, 160 Thermo, TPIS Airfoil, K&N Air Filters
14.4 @ 94mph w/2.0622 60ft
toronto formula
11-10-2015 06:17 AM
NinjaNife
08-23-2015 11:49 AM
86IROC112
08-17-2015 02:00 PM
knight72
08-10-2015 09:32 PM
