HEDDER QUESTIONS
HEDDER QUESTIONS
Got 3 questions here.
One: which hedders do best with our cars (hedman, hooker, summit etc.)? Im leaning towards either Summits in-house hedders, or hedman's.
Two: Is the ceramic coating worth the chunk of change?
Three: How easily do the hedders fit and hook up? Will i be able to do the work without welding or bending?
---Grady---
1984 Berlinetta.
LG4 305, 170 hp.
Rochester Quadraje(Comp. Controlled)
TH-700R4.
Flowmaster 80 series/ 3" cat-back pipe.
Accel Superstock Coil.
7.5 10-bolt rear/ 3.08's.
Edelbrock signature series air cleaner -w- K&N Filtercharger.
Pioneer head unit, Pioneer front 4X6's, Cerwin Vega rear 6x9's.
Daily Driver.
---Grady---
1984 Berlinetta.
LG4 305, 170 hp.
TH-700R4.
Daily Driver.
First, unless you work for hedman, they're called HEADERS, not HEDDERS. No offense. That outa the way, there is really no 'best' header for our cars. It all depends on the application. If you plan on keeping your car for a long time and/or drive in winter salt, you pretty much have to get either stainless headers (SLP) or get your headers coated. Jet hot coating does cost quite a bit and upon reflection, I wish I had gotton mine coated, although I dont drive in salt. As far as ease of installation, there is none. The only problem I had with my headers was the holes in the flange had to be drilled, I think most types of headers should line up/hook up just fine, no welding or bending unless you buy longtubes. Just know what your getting into before you start...and have another car to drive, because it will take longer than expected.
'83 Firebird 2.8
'89 Firebird Formula 350
Red/grey, t-tops, and a 3.27:1 rear
K&N, TB bypass, no MAF screens, CAI, full Accel ignition, no cats, Hooker Supercomp shorties, Hooker 3-inch catback
'83 Firebird 2.8
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
<font face="Verdana, Arial" size="2">Originally posted by Trigger84:
</font>
</font>
1987 Iroc 350
GTS headlight/tail light covers
Camaro SS Wheels w/Sumitomo HTR ZII 275 rear, 255's in front
K&N filters
Adjustable Borla cat back
Large tube runners
ported plenum
Holley afpr
SLP 1 3/4" headders (not installed yet)
FUTURE GOAL:
To go really F'in fast!!!
Some pics of it at
http://albums.photopoint.com/j/Album...949&Auth=false
