ARP 12pt stainless steel bolts for TES headers!!!!!!!!!!
Headers are about to go in, and i bought the complete set of 12pt stainless steel bolt for SB chevy's. Anyway the bolt for the headers is very small in length compared to the stock bolt. When i test fitted the header using the 12 bolt and it holds fine, im just scared it might loosen up and drop the headers. Has anyone used these 12pt stainless steel bolts, how are they, should i just order a set of stock bolts for the TES headers. Any suggestions.
92' camaro
New 305 block TPI conversion, Flat top pistons,Bore over .30 Forged parts all around,Edelbrock intake,ported plennum,ported corvette alluminum heads, accel cam,52mm throttle bodie, SLP runners Home aid cold air induction, Air foil,ford SVO 19lb injectors,fuel regulator,cloys timing chain, comp alluminum roller rocker arms and pushrods MSD 8.5 mm wires, bosch plattinum plugs, hypertech cap & rotor and coil, Edelbrock TES headers, free flowing catalytic converter and a 3 inch force II flowmaster exhaust system, and a 3 inch cutout,Zoom multi friction clutch, T-5 tranny,billenstien shocks&struts.
Soon to come!!!
Procharger system 12lbs o boost.
New paint job(hawaiin orchid purple)Cast alluminum ZR1 rims w/ 275 tires.
Favorite quote: "where ever u go, there u are"
Other car;
1971 plymouth Duster
Mods:340,edelbrock victor jr. intake, 650 4 barrel holley, heddman headers,40 series dual flowmasters, cold air intake,4:10 gears, just got a new paint job and cragar rims with 315 tires in the back.
:Yeah its not a chevy but damn how many 71' dusters have u seen in the streets.
92' camaro
Soon to come!!!
Other car;
i know someon knows,dont be a turd ![](https://www.thirdgen.org/messgboard/biggrin.gif)
92' camaro
Soon to come!!!
Other car;
92' camaro
Soon to come!!!
Other car;
Terrell351
06-13-2021 01:13 PM
ambainb
04-25-2016 09:21 PM
355tpipickup
08-25-2015 12:54 AM
