Ceramic coat your own headers?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I see nothing is there that would coat headers. It's all epoxy, adhesives and insulations.
2600ºF 901 Ceramic Fiber Adhesive & Coating
A creamy, high purity, Alumina Oxide based, ceramic composite.
Packaged in a ready to use, rich creamy paint form. It is easily applied by brushing, spraying or dipping.
Cures at room temp. to provide excellent resistance to oxidizing and reducing atmospheres, molten non-ferrous metals, steam, most chemicals and solvents.
Use 901 Fiber Based Adhesive for bonding porous ceramics, coating for flame, oxidation, corrosion and erosion resistance, forms a chemical barrier against diffusion and wetting in high temperature processing.
It might not be as good looking as the stuff jet hot uses but wouldent it work?
While I have not checked out that site, I know www.techlinecoatings.com and www.performancecoatings.com do.
1989 Camaro RS LO3 WCT5
http://350.StreetRacing.org
Hotrodboba400
12-10-2019 07:07 PM
sailtexas186548
02-17-2017 03:07 PM
redformula88
10-14-2015 06:08 PM
