305-Exhaust System
Car: 2003 SVT Mustang Cobra
Engine: 4.6L DOHC Supercharged
Axle/Gears: 3.55
305-Exhaust System
Is it worth buying a full exhaust system on a 305? Is it possible to take it off later and put it on a bigger motor?
It's all fun and games 'till someone looses an eye....then it's fun you can't see!!
1987 Pontiac Trans Am
-305 cid motor
-700-R4 Transmission
-K&N Air Filter
-Flowmaster 40 series
Muffler
-Yokohama Tires
-GTA Rims
-3" Exhaust Tips
-180 degree Thermostat
-2.73 Posi Rear End
-JVC Head Unit w/ Kicker subs!
-And a COOL LOOKING Flowmaster sticker on the dash!
WOO-HOO!!
*Long live the F-Body!*
-305 cid motor
-K&N Air Filter
Muffler
-Yokohama Tires
-GTA Rims
-3" Exhaust Tips
-2.73 Posi Rear End
WOO-HOO!!
1 Post
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
I highly recommend it. A lot of people on the board, Like Kevin91Z had his stock 305 dynoed and then had a 87 IROCZ exaust system put on and he dynoed it again and gained 8hp and 20TQ and that is just with another factory exaust! So if u went aftermarket 3" cat-back maybe, then u would see even more gains probably.
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
http://members.aol.com/j007golden/91firebird.html
For info on certain parts or mods go to the site below
http://members.aol.com/j007golden/modeval.html
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
Car: Take
Engine: Your
Transmission: Pick
Whats to gain by putting an '87 IROC exhaust on a '91Z? '89 and later TPI manifolds are "supposed" to be the best, plus you may have had the dual cats, plus, 305 TPI's got the same manifolds as the 350's. Whats to gain?
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
South East Thirdgen
Savannah, GA
'87 Trans Am
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
'97 Bonneville SSE
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
The '86-90 IROC's with the 305TPI engine had larger exhaust manifold outlets and a 3" opening at the end of the Y-pipe. The later 305TPI/A4 cars got the same smaller outlets (2 1/4" Y-pipe/cat) as the TBI cars; I know since my friend with a '91Z28 305TPI/A4 has one and my '87 IROC 305TPI/A4's stock exhaust had the 3" Y-pipe/cat.
Greg Westphal
'87 IROC 305TPI/A4
Greg Westphal
'87 IROC 305TPI/A4
Car: Take
Engine: Your
Transmission: Pick
South East Thirdgen
Savannah, GA
'87 Trans Am
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
'97 Bonneville SSE
1 Post
Engine: 3.8
Axle/Gears: Dana 60
Um, I don't know. But the guy I was talking about had 305 TBI exaust and he swapped to 305 TPI exaust.
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
Engine: 385 HSR
Knowing GM, their parts manuals are wrong. My friend's '91 Z28 had the smaller exhaust on it from the factory, and I've heard of and seen others like that.
Greg Westphal
'87 IROC 305TPI/A4
Greg Westphal
'87 IROC 305TPI/A4
Car: Take
Engine: Your
Transmission: Pick
I double checked my info, and I was wrong, but becuase of my mistake, I think I stumbled on something interesting. Check this out, I think you will be interested.
There were two exhaust manifolds available for the V8s. For camparison sake, I will use the Right Hand Manifold.
The L03 got the 10128448 manifold, along with the LB9 w/ auto, and the LB9 with an M39 5-speed.
The L98 got the 14094064, HOWEVER, although this is the "350" manifold, There were some LB9s that also got the "350" manifold, but you had to get the MK6 5-speed. The LB9s w/ MK6 got the 350's 14094064 manifold.
So whats the difference between an M39 and an MK6? Beets me, my RPO book says they are both BW 5-speeds. Obviously, GM set aside some 305 5-speeds for racing and wanted a little extra "boost" so they used the 350's larger manifolds. Does this mean you also had to get the 1LE package to get this? I don't know. That would also mean that the LB9/1LE package included a different T-5 tranny, possibly a stronger tranny?
South East Thirdgen
Savannah, GA
'87 Trans Am
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
'97 Bonneville SSE
South East Thirdgen
Savannah, GA
'87 Trans Am
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
'97 Bonneville SSE
I have read somewhere (sorry, I can't give a specific quote yet) that the 1LEs did in fact get a different 5 speed tranny. The overdrive wasn't quite as deep. Probably so they could go into 5th while racing and not have too much of a torque loss. I think it was the 1LE website.
'92 Z28
5.7 TPI
T-56 six speed
Pro 5.0 shifter
3.73's
SLP 1-3/4" Headers
SLP Cat-Back
52mm TB
Extrude Honed Intake/Ported plenum
Hypertech Prom
'92 Z28
5.7 TPI
T-56 six speed
Pro 5.0 shifter
3.73's
SLP 1-3/4" Headers
SLP Cat-Back
52mm TB
Hypertech Prom
Ok, guys, my dad put an 85 IROC y-pipe, cat, and cat-back on his 92 TBI RS, and gained 8 HP and 20 TQ.
The difference in the exhaust manifolds and the T5's is whether you got the G92 package or not. The non-G92 3.08 rear end cars have single cats, and the TBI's smaller exhaust, with a 2.95 first gear. The G92 package is 3.42 rear end cars with dual cats, the 350 TPI exhaust, and a 2.75 first gear. This is for 89-92 cars.
I wouldnt bother switching, there is very little difference in the exhaust manifolds. Get headers, preferably SLP's . But the cat-back is definitely worth changing on any f-body.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
Headers? If you're going to go through all the work of changing manifolds, all for the potential gain of a couple horsepower, why not do something worthwile and put a good set of headers on?
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
The IROC Homepage
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
My car has the RPO M39 : TRANSMISSION, MAN 5 SPD B0RG WARNER, 77MM, 2.95
I have an 87 LB9 with G92 and a single CAT. The original stock manifolds are part numbers 14094063 & 14094064 and measure 2.19 inches inside diameter of the outputs.
Just more food for thought....
Originally posted by Jim85IROC
Headers? If you're going to go through all the work of changing manifolds, all for the potential gain of a couple horsepower, why not do something worthwile and put a good set of headers?
unless you are restricted by a class or something along those lines to stay with a stock manifold, headers will gain you the best performance increase. save up for a few extra weeks and get the headers, you WON"T be dissapointed.
im gonna be running headers with 305 in both my cars
until some day i locate an 80-up 350 engine for them
the same headers fit all the sbc with stock iron heads anyways
normal straight plug heads
the more mods you do to an engine to allow it to more easily get and let air and and out then the better
that includes headers
GM did it factory all the time, like with the L69 HO305(and some others) third gens, they put 2.75" pipe on those, instead of the usual 2.5"
good luck
good luck
Pac J
05-17-2020 10:44 AM
[Sold] Flowmaster exhaust system
Night rider327
10-09-2015 09:25 AM
Night rider327
09-25-2015 04:47 AM
