carb heat after headers install?
Guest
Posts: n/a
yes men! how do we get carb heat after we install headers?, i can't see any hot air source on the headers, does it mean that once you've don it there will be no more carb heat? or there's some aftermarket adaptor i should know?
thanks!
thanks!
Are you talking about hot air for the air cleaner or exhaust heat for the intake manifold? The hot air problem is simple: just fabricate some sheet aluminum or flashing and make you a heat stove with a nipple to attach the hot air hose to.
I think there are heat riser valves that attach to the collector to restore exhaust heat to the intake, but I don't know who makes them.
86IROC112
08-17-2015 02:00 PM
