Flowmaster mufflers make 30HP and 40ft.lbs of Torque????
Old 12-08-2000 | 08:01 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
In JEGS it says that the Flowmaster 80 Series makes 30 more HP and 40 more Torque!!!!
Looking For:
87 IROC-Z 350 TPI
84 TRANS AM 305 H.O.
Old 12-08-2000 | 10:11 PM
MrJ's Avatar
MrJ
Its called advertising. They put a stock restrictive exhaust on a big block, dyno it, then remove it and replace it with the Flowmaster and get that increase. A Thirdgen would be lucky to see 7hp from just a muffler swap alone.
91 Trans Am WS6
Bright White
5.0 TPI auto
Flowmaster 3" 2 chamber catback
Trans Go shiftkit
2000 stall converter
supposed 'peanut cammed' car (yeah, right)
Built on Wednesday
Old 12-08-2000 | 10:18 PM
KamaroZ350's Avatar
Car: 2008 Jeep Wrangler Unlimited
I sure didnt gain that much with mine.
1991 Z28 Camaro L98
5.7 T.P.I
http://www.bright.net/~rwig/BandetZ28.jpg
http://www.bright.net/~rwig/BandetZ28-2.jpg
Old 12-09-2000 | 12:09 AM
Dan87IROC-Z's Avatar
I think that 30/40 is an exxageration, but it did a good deal for my friends 88 IROC 305, not bad for $80. It did more than his AFPR did and he paid about $80 for that.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET : 14.32 @ 97.7mph
(corrected for elevation)
Soon to come: LT4 HOT Cam, Air Flow Research 190cc Heads, 2800 RPM Stall Converter and SLP 3.70 Rear End Gears.
Navy8125
08-25-2015 08:25 PM
midias
08-22-2015 01:42 AM
Dialed_In
08-20-2015 01:45 PM
Thirdgen89GTA
08-20-2015 12:11 PM
gta power
08-13-2015 06:15 AM
Quick Reply: Flowmaster mufflers make 30HP and 40ft.lbs of Torque????
