1984 camaro 305 lg4 eng. code H
Car: 84 berlinetta
Engine: lg4
Transmission: 700 r4
First I would to thank the senior members who have me thus far. Now it is to my understanding I can use EDL 6872 which applies to 1986-1990 5.0/5.7 TPI CAMARO/FIREBIRD with single 3 inch inlet slip-on cat on my car. Every thing else is the same,air,oy2,and it is simple step by step process holding back the fact that I have to change the cat to a 3 inch slip fit inlet and the cat back piping to coinside. PLEASE tell if I'm wrong. Also the Catco direct fit is 2 inches shorter than cat for the LG4 system. Will EDL TES make up the positioning? parts numbers as follows EDL TES 6872/ CTO-9118/EDL cat back 5672 for applications with a single Catalytic converter 2 3/4" stock intermediate pipe- 3" inlet\ dual 2 1/2 outlets. Again correct me if im wrong on any of the parts.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
If you buy headers & y-pipe for '86-'90 TPI single-cat system, direct-fit cat for '86-'90 TPI single-cat system, and cat-back for '86-'90 TPI single-cat system, it will all bolt together, fit on your engine, and fit within your chassis. Relative sizes to the LG4 parts is irrelevant.
Any particular reason you're looking at the Edelbrock parts? Can't say I'm too impressed by the 2-3/4" I-pipe.
Car: 99 Formula
Axle/Gears: 342
Re: y pipe
Originally posted by The Chad
I just wanted a bigger Y pipe for better flow and possible on down the road 350 swap. Tell me better and I'll go with it.
Hooker 2055 headers, Hooker cat-back.
Car: 99 Formula
Axle/Gears: 342
Car: 84 berlinetta
Engine: lg4
3 inch
Can I just buy a 3 inch cat back for this application and be in good shape. Matching engine codes for new set up was hard for me,so I stayed with Edelbrock.
Engine: LS1/LQ4
If you're looking for a complete exhaust, go for the VIN code "F" or "8" in '86-'90 model years. That's the TPI single cat system. Stay away for anything made for LG4 VIN code "H".
Headers: Hooker 2055 $350
Cat: Catco 9118 $117
Cat-back: Hooker 16823 $260
Plus shipping, of course.
Car: 99 Formula
Axle/Gears: 342
colton_carlson
03-08-2019 01:21 PM
84z96L31vortec
08-20-2017 01:16 AM
84z96L31vortec
08-10-2015 09:27 PM
