TES OR SLP?? headers
which are the better headers? in perfromance and easy to install(tpi)? also in longevity,, i dont want to be replacing them in a few years..
[This message has been edited by ron rizzotti (edited October 03, 2000).]
From what I have heard, the SLPs are better for the all around headers. They are also about $200 more than are the TES, so its all up to you.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES 1 5/8" Headers, Hooker Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Components, K&N Filters, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET : 14.3 @ 97mph
(corrected for elevation)
L98 TPI 350 (5.7L)
SLP headers for sure! The difference in quality is easy to see. And they're even on sale right now:
http://www.slponline.com/slpperforma..._specials.html
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
SlP are better quality but are they worth the difference in price? MY TES are great and seem to be made quite well. Check out my post on the results of TES headers I just installed.
Car: 88 IROC
Transmission: auto
Like mentioned above, slp's are on sale right now!!! I just ordered mine for 400 bucks. You will even save money on slp's rather than the edelbrocks because the slp's are stainless steel, and not necessary to coat.
Mods:Hooker Aerochamber 3" exhaust, gutted kitty,
March 2 piece underdrive pullies, smog pump gone,;these two made a very noticable difference.
14x4 K&N open air element filter-the best mod so far
Eibach springs with KYB's all around.
Appearance: Harwood cowl hood, Z-28 wing, painted black(7/20/00)-original color was light blue
*All these mods were made this year
Stock Options:117,000 miles on motor, 5spd, TBI, 305, T-tops
Run a best of 16.7 @85mph with traction problem. Have to try again sometime.
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I have only good things to say about my SLP 1 3/4 ones. I had mine coated though.
James
If the women don't find you handsome they should at least find you handy
James
If I could do it again, I would get 1 3/4 instead of the 1 5/8. So, for a 350, go with the 1 3/4.
L98 TPI 350 (5.7L)
L98 TPI 350 (5.7L)
Car: 89 Formula 350
Engine: 360 / HSR
I think the fact that the SLP headers are only available with 2.25" collectors is a MAJOR drawback! I'm pretty sure the Edelbrock primaries are 2.5"
Other than that the SLP's are better but the small collector size has kept me from buying a set. I wish they made 'em with 2.5" collectors!
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
I like SLPs design over the TES, especially at the Y pipe. The SLPs use a true Y connector where as the TES looks like it was pinched together to fit in together. BTW, these photos were taken before I put in the SLPs. My uncoated TES looks rough after 5 years: www.angelfire.com/ab2/rods/images/ypipe.jpg www.angelfire.com/ab2/rods/images/pass_header.jpg
1989 IROC-Z, ZZ3 shortblock with some bolt-ons.
13.20 @ 108.69, 2.2 60' on "Road Hugger" radials and dead Auburn posi.
[This message has been edited by IROCZZ3 (edited October 11, 2000).]
Car: 89 Formula 350
Engine: 360 / HSR
IROCZZ3 - have you tried both the Edelbrock and the SLP headers on the same car? Can you tell us if there was much of a performance difference? Just curious.
Try Hooker Super Comp part # 2055
50 state legal 1 5/8 well amde and can be had for $329 including shipping with no install or any other pipe to buy. SLP even on sale still totals over $500 when you tack on $40 for shipping $70 for install kit and $30 for the connector pipe.
Strip the paint and buy a $4.95 can of 1500 degree aluminum color paint and you are good to go. Its working great for me.
88 GTA 350 TPI A4, Digital Dash, Black/Tan T-Tops, 39,000 original miles. WS6 suspension. 9Bolt 3.27s.
MAC Catback, Airfoil, K&N, Transgo Performance Shift kit, Rerouted tranny bypass switch to OD. 160 stat with new fan switch, rerouted coolant lines, relocated air temp sensor out of intake, hi flow water pump, homemade cold/ram air, hypertech crank pulley, Hooker 50 state legal Super Comp Headers
what about flowtech headers, are they any good?
jgr,, was the install of the hooker headers straight forward? any problems occur?
[This message has been edited by ron rizzotti (edited October 10, 2000).]
Car: 87 Buick GN
I put a new Catco cat on at the same time with the header swap. I used to run a gutted cat with the TES.
But when I took it to the track I ran 4/10ths slower and 6 mph slower in the traps but that wasn't from the headers. I'm a retard- I later found two burned plug wires that were laying on the primaries because I didn't route them correct. I disconnected my knock sensor too but that might have put me in limp home mode the whole time at the track and hurt performance too.
I recently acquired an LPE 219 cam I could use the extra exhaust flow. HTHs.
The Hookers fit great, no major problems, just a little tough on getting some of the bolts in.
I just finnished putting in my SLP 1 3/4" headers. SLP recommended the 1 3/4" for 350's and the 1 5/8" on the 305's. The only thing is that they are super tight on the driver's side. You might have to "ping" one of the tubes in to clear the steering column, or shin the motor mount up a C-hair. SLP warned me of this before purchasing. They are on sale for $350 but you need the mounting hardware and Y pipe which is anouther $80
Now that they are in - I am very glad to have stainless headers, they have plenty of room for plug wire & stuff, their hardware kit comes with everything you need including wire protectors!
92 Z28 - 5.7 - Black/Grey Leather
Macewen White Faced Guages
SLP T-RAM, 24lb/h Injectors
Accell 52mm Throttle Body
SLP 1 3/4" Headers and Cat Back Sys.
My T-Rammed L98
My T-Rammed L98
redformula88
10-14-2015 06:08 PM
TX-SleeperC5
09-24-2015 03:13 PM
