Anyone heard about Hooker Super Comp Shortie Headers 50 state legal
Everyone talks about SLP and Edelbrock TES and the ones I have seen put Hookers on are just the Headers no Ypipe or emmisions stuff. Jegs, Summit and Internet Racers Supply carry a Hooker Super Comp Header 50 state legal 1 5/8 just like the other brands. Does anyone have any opinions or hear anything about them and how good they are. I just put a set on mine and am looking for others results.
88 GTA 350 TPI A4, Digital Dash, Black/Tan T-Tops, 39,000 original miles. WS6 suspension. 9Bolt 3.27s.
MAC Catback, Airfoil, K&N, Transgo Performance Shift kit, Rerouted tranny bypass switch to OD. 160 stat with new fan switch, rerouted coolant lines, relocated air temp sensor out of intake, hi flow water pump, homemade cold/ram air, hypertech crank pulley, Hooker 50 state legal Super Comp Headers
Doug Glad, from Car Craft, has the Hooker shorty 50 state legal 1 5/8 headers on his '91 Z. He has one of the first sets made for dual cat engines. He showed them in one of the buildup articles in Car Craft during this past year.
He is using them with his 383", Super Ram, Vortech blower, and nitroused engine that is in his car now, which will be featured in next months issue of Car Craft.
FORMULA 350 TK
Southern California 3rd Generation F-Body OrganizationŠ
FORMULA 350 TK
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
I have the Hooker Super Comp headers (model #2055) on my '87 IROC, and they are fully emissions legal. They have 1 5/8" primary tubes, the air tubes, O2 sensor fitting, Y-pipe with 2 1/2" downtubes and 3" at the end, and they bolted right up w/out having to jack up the engine or remove the steering shaft.
The only problems I had with the headers were having to enlarge the bolt holes on the flanges to make it easier to get the bolts in. It will also make it much easier to thread the bolts in by hand if you run a tap through all of the bolt holes before installing the headers. Removal of the oil dipstick tube was necessary, just remember to clean the end of it off really good to make reinstallation much easier.
HTH,
Greg
HTH,
Greg
hectre13
09-08-2015 03:38 PM
