Flowmaster restriction?
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
I Bought a 3 inch flowmaster kit for my car when it still had the 305 in it. Its a 3 inck setup with a 2.5 inch exit, I'm confused why they didn't just make the whole thing 3 inch. Now that I had edelbrock TES, and a 3inch cat I'm wondering if this 2.5 inch exhaust is causing a noticeable restriction. About the only thing this tailpipe is good for is the sleeper look, but the lopey idle and hoodscoop kind of offset it now. I figure it'll cost me about a hundred dollars to get a 3 inch flowmaster muffler and tailpipe and I want to know if you guys think it'll be worth it
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 268 grind. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, ****ty stock converter
13.24@104
13.24@104
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
I say get away from flowmaster, i've heard better reports of other cat-back systems liked dynomax and hooker aero chamer mufflers. I myself felt a reduction in HP when i installed my flowmaster cat-back. Maybe someone else would like to elaborate on this.
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-Rebuilt 700R4 Tranny
With the goodies to go
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
89 IROC-Z 350 TPI
-Flowmaster Catback
-K&N Airfilters
-Ported Plenum
Get the hell rid of the flowmaster. It's definitly a restriction to your 350. What size pipe do you have goin from your cat to muffler? I'd get a full 3" system.
With your mods you definetly need a 3" exhaust. You might be robbing yourself of some horsepower with the 2.5". I personally thought Edelbrock's Catback along with the headers on my 88 RS sounded nice. I think I have a wav file on my computer off a 90' RS 305 that had the exhaust gutted and everything with Edelbrock. Just make sure you get the Z28/T/A 3" Exhaust, it says it will only fit for those models but there fibbing. I did it on mine, the only diff is one is 2.5" and the other 3.0"
90 Iroc LB9 5spd G92
Dual Cats, 3.42 Borg Warner w/Posi, TPIS Airfoil, K&N, 160 Thermo, Mobil 1 Extreme Formula 0W-30 Synthetic Motor Oil, Home Made Ram Air, ACDelco Plugs, 8.8mm 300+ Accel "Race" Wires, Accel Cap And Rotor, Ported and Gasket Matched Plenum, TB Coolant Bypass
My 3rd Gen Web Page
My 3rd Gen Web Page
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
thanks for the help, I think I'm gonna dump the 2.5 inch muffler and get a warlock 3 inch, other than my tail pipe, the whole thing is three inch.
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 280 grind. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, ****ty stock converter
13.24@104
13.24@104
[Sold] Flowmaster exhaust system
Night rider327
10-09-2015 09:25 AM
