Post Your Exhaust Setup...
#101
Car: 2002 Formula Firebird
Transmission: 4l60e
350 with 9.6:1 compression
edelbrock TES headers, no cat, 3'' hooker catback exhaust.
Used to have hedman longtubes, h pipe, true duals, 2 chamber flows...to loud and to low.
#103
i got a 89 iroc. 305 tpi. i currently have a hedmen headers, accel 8.8mm wires, hypertech chip (stage 2), open box, free mods, accel coils, flowmaster exhaust, tornado, air fowl with stock throttle body, b&m shifter, monster tach, posi, stock gears, modified mass air flow sensor. i was running 15's in hawaii. i was told that with these mods it suppose to be quicker. so what do you guys think with these mods? should i be in the 14's since we adjusted my cars timing. it was on 28 degrease. it was real off. so we adjusted it to 7 degrease. should my time be better now?
#104
Car: '85 Z28
Transmission: WC T5, 3.23 posi
Is that 28 degrees base timing? If so that would cause some power loss. Base timing should be about what you set it at, on a stock motor. More modified motors may need more base timing though...
#105
Car: Check The Sig
tornado... gone
hypercrap chip... gone
timing... go to 10*.. thats about as far as that hypercrap is taking you... cant go much farther then that with out the ecu correcting you and setting it back. I need to find someone with an advanced timing light so i can start playing around.
#106
Car: 1990 Formula
Engine: treefitty
Transmission: stick
Edlebrock TES headers, Dynomax cats, 3 inch catback with a Spintech muffler w/dual 3 inch outlets, capped w/Hooker Large Bore tips w/resonators(3"inlet-4" outlet).
#107
Car: Camaro RS
Engine: 305ci TBI
Transmission: TH-700R4
yeah im hopen to rip out my cat and just run headmen headers/Y-pipe all the way to the muffler. Have to get some money
SSBO
SSBO
#109
1 Post
Car: 1990 Camaro RS
Engine: LO3: 305 TBI
Axle/Gears: 1997 Trans Am rear w/ posi -3.23
305 TBI w/ 1 5/8" VHT painted Hooker Super Competition shorties and y pipe, hi-flow CATCO cat 3in./3out. , Hooker Aero- Chamber Catback with 2 1/2" tailpipes and turndown tips.
#110
1 Post
Car: 1986 Z28
Engine: 355
Transmission: th400
on the Z28, i've got slp 1 3/4 headers, a 3" bend to a cutout, to a flowmaster single in single out . american thunder or force 2 i think.. probalby the force two. that's got a vortec headed 355
the formula.. stock manifolds, stock stuff till you get to the same 3" force 2 catback as the Z28 that's a 305 tpi 5spd
#113
1991 Camaro Z-28
5.7L V8 TPI
Coated 1 3/4 Slp Headers
Dual Flowtech Cutouts before cats (Electronic ones soon)
Dual stock cats
Magnaflow 3" stainless cat back with straight through muffler and 3.5" Dual polished Stainless tips
Rich and reasonable untill 2000rpm when it gets a lot louder, which can definetly make a reasonable point before burning a mooshtang (Closed cutouts)
Unbelievable and undescibably loud but still low piched and not at all scratchy. MMMMMMM, it gives me the chills even thinking about it. Un fortionately the cops arent happy about it. (open dual cutouts)
*Does any one know exaust volume laws or where i can get them for Illinois, the chicago land area, specificaly Deerfield where i live and dirve the most.
5.7L V8 TPI
Dual stock cats
#114
Car: Black 89 Formula
Engine: ??????????
Transmission: ??????????
do you have a sound clip becuase im going to run that set-up?
#115
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Pontiac 455 With Hooker Super Comp HEaders. 3 Inch collectors into 3 inch cutouts into 3 inch flowmasters true dual exhasut. Oh yah its on my first gen bird
#116
82 Indy pace car, 383, allumicote shortie headers, true dual following stock exhaust route! no cat, glasspacks to dual 3" tailsout the drivers rear! Too loud!! changing to turbo muffs!
#117
Car: 91 RS
i have a 91 rs 305 tbi and i was thinking of getting slp headers right into side pipes for jc whitney. take out the size g/fx and put them there. i was just wondering if anyone has done that
#118
Car: '85 Z28
They have, and it doesn't look very good. Trust me. I would post pics of one that had sidepipes, but I'm in the middle of redoing my computer.
#119
Car: 1988 Trans Am GTA
Engine: 5.0 TPI
Transmission: TH700-R4
1 5/8" Edelbrock TES Headers w/AIR and 3" Y-Pipe, 3" Catco Converter, 3" Flowmaster Cat Back w/ 80 series American Thunder muffler (3"in/dual 3"out, Stainelss Tips)
Pics in sig site.
Pics in sig site.
#120
Originally posted by nolanr0413
stock mailfolds and cat , no muffler and then two ss z28 style tips. it sounds sweet .
Y pipe into a 3" cat and 3" pipe all the way out (no muffler).
Still working on what I want to do for the tip(s).
I used to have the 2.5" pipe w/out the cat and a crossflow
flowmaster, but my motor didn't like the restrictiveness of the
flowmaster. The car run's 100 times better now running just
the cat and no muffler... not to mention it sounds great!
#121
Engine: ??????????
Hedman headers with 1 5/8 primaries and 2.5 y pipe to stock exhaust system with a 2.5 inlet flowmaster muffler.
man the headers ARE worth the money they cost me 328.98 the best amount of money i ever spent had to take of some 1/4 time.Night and day difference.
#122
Car: 86 TA
Engine: 383 Stroker
Exhaust setup
Here's mine...
Dual Exhaust 2 1/2 pipe, Dynomax racing bullets and Hooker satin coated headers.
Engine:
383 stroker
Holley Street Avenger
March Pully system
Be Cool Radiator
Dart II Heads
Forged pistions, crank
Eagle rods
Crane roller rockers
Edelbrock RPM Air gap intake
700R4 Trans
Hughes 3600 lockup stall convt.
Engine:
383 stroker
March Pully system
Be Cool Radiator
Dart II Heads
Eagle rods
700R4 Trans
#123
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
Mike...just to let you know, it wasnt the Flowmaster that was restrictive on your car, it was the kinked up stock 2 1/4" pipe you were running. Of course its gonna run better with 3" all the way out. By the way...you gotta hear your old muffler on my 84. Sounds great. Might have woke it up a little bit too. See ya at the Pavs.
Joe
Joe
#124
Joe
Joe
2 1/2" piping throughout the entire set up. Besides, running
the 3" cat with the new piping sounds a lot better than that
cross flowmaster. *L* Too bad there's no room for a 40 series.
I'm glad you like my old muffler... I might be getting a dynomax
bullet put on...or I'm going to finish off the tip(s).
Mike
#125
Car: 4 Mopars total
2 1/4, 2 1/2...who cares. Was still choking it. Hell, the stock exhaust on my 84 is choking it. And my L69 exhaust is a lot better than your old LG4 exhaust. What I wouldnt give to have my old Edelbrock headers and SLP catback back in my possesion. Im glad youre happy with your new exhaust, but if I were you, id be putting a muffler on that thing. BTW, you sure youre gonna use those headers? Ill be more than happy to take them off your hands. Gimme a call. Later man.
#127
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
Originally posted by 1bad91Z
Hooker long-tubes (coated 2210's), modified mufflex y-pipe, car-sound high flow cat, flowmaster cat-back
Wow, where did you put the cat?
Anwyays, my setup- zz3 350, trickflow heads, hooker long tubes, mufflex y-pipe, hooke 3" cat back...
SOUNDS AWESOME!
#128
Originally posted by DARCOM
yes i had it notched i like it ,it gave me all the clearance i needed.
heres another view
heres another view
#129
Originally posted by 383backinblack
thats kinda neat, but why wouldn't you just build a double hump cross member to do that instead of cutting up your frame rails?
Ben
#130
1 Post
Car: 89 Formula Firebird
Engine: 305 - Demon 525
I'm different,
Vortex catback with damn near straight through design designed by Cherry bomb, Edelbrock tubular exhaust headers (black ones, not the shiney nice ones... ) 2 1\2 that should have been 3 >.<
#131
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
as of today
Edlebrock TES 1 5/8 headers, Catco 3"inlet/outlet hi flo cat, Flowmaster American Thunder Cat-Back exhaust w/ single 3" inlet & dual 3
sounds really well even on my 305 tbi
#132
Car: 1987 TransAm
Engine: 350 Goodwrench
Transmission: 700R-4
1987 carb. 350 cu. in. Firebird. Hedman shorty headers(pn 68470), Hedman Y-pipe(Pn 17470) with 3" end replacing 2.5" end and Flowmaster catback system for single 3" cat (pn17151) without a cat. Flows great , sounds good, fits well.
#133
Car: 84Z28
Engine: 12:1 355
Transmission: fairbanks turbo350
I have headmen longtube headers with a flat colecter and 3" duels and mufflers and pipe i made at work. it sounds great and i only lost a 10nth in the 1/8 at the strip
#135
Lost a tenth compared to what exhaust? What do you run? What engine and tranny combo do you have. If that is compared to stock exhaust I would say you need to tune it if it is carbed. Maybe the exhaust is just to big for your motor. Dual 2.5 is about equal to 3.5" which is what I have. A cross pipe such as an h or x might help out with loss of torque if that is what has caused you to slow down. Also, do you have any pics of the ground clearance. That is basically how mine is run except I have the hooker long tubes and used s pipes to move it into the driveshaft tunnel since the hookers seem to sit a little wider than the hedmads. I used bullets also. My ground clearance is really pretty good and I dont really scrape on anything. I was kind of wondering how yours does since you have the larger pipe and normal sized mufflers.
Ben
Ben
#136
Car: 1992 camaro RS
Engine: 305 TBI
Transmission: T700-R4
In my earlier thred i had stock exhaust.
As of today i have.
Hooker headers, hi-flow cat, 2.5" mandrel pipes, flowmaster 80 series. and sum sparkly exhaust tips too.
Yippy!
As of today i have.
Yippy!
#137
Car: 84Z28
Engine: 12:1 355
I had my car tuned for open headers,i just put them on to see what it would run. i could of played with the timing a little,but i didnt. it runs 7.30s at about 95mph in the 1/8, best 60' was 1.61. i have 2" drop spindles and the colecters just barly skrapes on big dips, but large speed bumps would be a diferent story. my motor is a 355 withe brownsfield raised runner aluminum beads solid roller cam roller rockers 12.1 forged pistons brodix intake berry grant 750 holley. fairbanks turbo 350 3500 stall 9" curry with 4.86 gears.
#139
OK, thats cool. Sounds like it worked out pretty good then. I didnt know what exhaust you were running to start with(open headers). What kind of mufflers are those?
Ben
Ben
#140
Car: 84Z28
Engine: 12:1 355
I was running open headers. the mufflers,I designed and built them at work. i have made a couple different designs.i have some strait through ones i made that im going to polish up and use instead of the ones you see in the picture.
#141
Car: 1989 IROC-Z28
Engine: HSR-L98
Swain coated long tubes into 3" head pipes and then into a single 3.5" intermediate pipe running into a Dynomax welded ultraflow muffler. Still undecided in the tailpipe, hidden or slash cut.
Stock L98 short block with vette heads and hot cam, 1.6 proform RRs, stealth ram intake and stock TB.
320rwhp
340rwtq
http://webspace.utexas.edu/drews/automotive/exhaust
Drew
'89 IROC L98/M6
320rwhp
340rwtq
Drew
'89 IROC L98/M6
#142
Car: '82 Z28
Originally posted by EvilCartman
Sig next engine will require dual 3 1/2 inch
#143
Hooker 2055's with the air tubes cut off and the flange modified, and jet hot coated, mac offroad pipe, flowtech 3 inch cutout welded into the offroad pipe also jet hot coated, and flowmaster 3 inch dual exit catback.
#144
Car: 1965 Chevelle SS
Engine: 355
Transmission: TH350
Stock manifolds, stock cat, Edelbrock 3" catback. Pretty quiet - the way I like it. By next spring, I will have hooker lt's and y-pipe without the cat.
#145
Engine: 355
Transmission: TH350
#146
Re: Post Your Exhaust Setup...
1986 camaro sc
357 sbc
11.1 kieth black pistons
double hump heads
556 lift 315 dur cam
roller rockers
wiend hi ram intake
dual 450 holleys
long tube headers
hooker mufflers
tru dual exhaust
4.10 rear gears
best 1/4 of 11.26 @ 136
357 sbc
double hump heads
roller rockers
wiend hi ram intake
dual 450 holleys
long tube headers
hooker mufflers
tru dual exhaust
4.10 rear gears
#147
Car: 1987 TransAm
Have revised exhaust on 1987 Firebird since 9/9/03 post. Still have Headman shorty headers (pn 68470) and Headman Y-pipe (pn 17470),now with 3.5" tail pipe. The rest of the exhaust system is 3.5" Mufflex with Flowmaster muffler. A little louder but not bad. More horsepower, but not quite as good fitment.
#149
Car: 86 Iroc Z
Engine: 406
Transmission: 350 Turbo
Axle/Gears: 373
Shortie Headers with dual 2 1/2 inch pipes run into a Mufflex 4 inch system out the back with 1 single tailpipe.
I've got more ground clearence than the car had stock. Sound file in the sig.
