Callies vs Scat - Crankshafts
im building a 383 and im hoping to push 400hp before a 125 shot of nos, whos going to hold up better for me? or is there another good cs manufacture that is very respectable that i dont know about. which model would you also decide on?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 92 camaro, 06 trailblazer ss
Engine: 5.0 tbi, 6.0 ls2
Callies crank you dont need one not with 525 horse Scat cranks depending on forged or cast will be stronger than you need. other companies to look at
Most of these cranks cost more than $1,000 all top of the line stuff.
Callies
Crower
Cola
Lunati
Scat
Cat
LA Enterprises
and try here http://www.performancewholesale.com....duct_range.htm
Callies
Crower
Cola
Lunati
Scat
Cat
LA Enterprises
Car: 89 Iroc Z
Engine: Carburated 427 Smallblock
Transmission: 400 Turbo
Callies has the best reputation of the two, but they will run several hundred bucks more than a Scat crank. When I built my engine I went with Cola, they have quality cranks and are less expensive than Callies and better quality than Scat(a friend of mine runs them in the engines in his drag car and he races super gas and has never had a crank failure). I don't have Cola's telephone number, but you can find it in most hot rod magazines, call them and talk to Raoul (sp?) he's very knowledgeable and personable and will answer any question that you have about cranks. Hope this helps.
Bruce, "70GTO"
Bruce, "70GTO"
I don't want to sound bias (Callies is one of my late model sponsors) they are the best cranks for American V8's (word around the pits). Used Crower in the past, very good too. Number one used crank used in NASCAR. You may want to look at their DragonSlayer line. 700 bucks for a 4340 forging not bad.
We turn 8900 rpm's for up to 200 laps each weekend...never a crank falure...valvetrane...thats another subject...lol
Hope this helps.
Hope this helps.
Hotrodboba400
12-10-2019 07:07 PM
LT1Formula
10-08-2015 08:34 PM
Andrew Prakash
09-08-2015 11:48 AM
