Large cap HEI distributer
hi everyone
quick question. Is anyone running a large HEI distributor in their third GEN? I recently got a blueprint engines 350 and it came with a coil in cap (large cap) distributer and I am wondering if it will fit? or if I will have to get another small cap distributor with divorced coil?
if anyone has any pictures of their set up, that would be super helpful too!
thanks!
thanks!
Location: Franklin, KY near Beech Bend Raceway, Corvette Plant and Museum.
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
Re: Large cap HEI distributer
Third gens were designed to run a SBC with a large cap HEI. F-body didn't switch to small cap HEI until 1987.
T.L. (08-11-2024)
Is your car going to be computer controlled or just a normal old school carburetor?
Carb all the way. My goal is absolute simplicity. I’ve never owned an HEI ignition system before. But my hope is I can send 12 V to it and be up and running minus the tach signal.
I don’t believe I need an ignition box or anything like that?
Thanks Airwolfe for the info. I’m just trying to get all the parts ready. And I figured if I needed a distributor, I’d rather order it now than later.
Oh, I’m going to use the tach signal. Reading back I can see how that could look otherwise. I just meant as far as getting spark was concerned.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Received 1,815 Likes
That makes more sense.
Yes, all you have to do to get spark from it, is connect 12V to the Batt terminal and ground the case.
T.L. (08-12-2024)
Generally yes. Since the negative batt cable is connected directly to the block, or to a bracket that's bolted to it, no ground straps are involved.
jayk2k3
08-20-2008 07:55 PM
