LT1 Swap Help DENVER,CO.
Car: 1992 Camaro RS
Anyone in Denver, CO. that has done an LT1 swap on a Camaro, I got $ and would compensate someone for their help.
Car: 92 Camaro RS
Engine: 5.7 LT1 (Bored 95 Corvette Block)
Transmission: T56 - 6 Speed
Axle/Gears: 4th gen posi with 3.42 gears
Re: LT1 Swap Help DENVER,CO.
Which version of the Lt1? Gen 1, 2 or 5?
Car: 1992 Camaro RS
Car: 92 Camaro RS
I swapped a LT1 (4 bolt with Corvette heads) and T56 trans in my 92 Camaro RS. It was originally a V6 3.1, 5 speed. Unfortunately I don't live in Colorado. The power difference is amazing.
raybob9289 (06-07-2024)
Car: 1992 Camaro RS
Engine: LT1, L98
Transmission: ZF6, ZF6
Axle/Gears: 3.45, 3.31
I'd help...but I'm in Park City, UT. That'd be an enjoyable job. You'd have to get the car here which I'd guess that you don't want to, or have the means to do.
Car: 92 Camaro RS
I bought. 95 Camaro z28 from a guy. He had swapped the Camaro block for the Corvette block. I used the 95 wire harness, pcm and emissions for my car since I live in CA. Using the 95 harness there's only 7 or 8 wires that need to connect to my 92 to run the engine. I ended up repairing and replacing worn wires on the harness and extended the wires by 3ft so I could mount the PCM in the dash like the original PCM.
Car: 1987 Camaro IROC-Z
Transmission: T56 6speed
Axle/Gears: 3:45
Car: 92 Camaro RS
It extended the PCM wires so the harness could reach the the dashboard. Then I mounted the computer in the same spot as the original computer on the far right side of dash.
raybob9289 (06-08-2024)
Car: 92 Camaro RS
I extended the PCM wires of the harness so it could reach the dashboard via a wire port on the front passenger wheel well. Then I mounted the computer in the same spot as the original computer on the far right side of dash.
Axle/Gears: 3:45
Car: 92 Camaro RS
Nice. That's where mine sits. I didn't take my dash apart though. Probably would have made things easier.
