Serpentine Belt System Help!!
Car: '91 RS Camaro
Engine: Custom Small Journal 327
Transmission: T-5 5 Speed
Axle/Gears: GM 10 Bolt 3.08
Hey ThirdGen Nation. I've got an interesting question. I'm sure someone here has gone through this already. I have a 91 RS Camaro with a 305 TBI. My question is simple. Is it possible to use the factory accessories, brackets and the belt system on an old small journal 327? The new aluminum heads that I'm putting on appear to have been drilled for the newer accessory drive systems. I'm just curious with the taller valve covers that I have to run to clear my Valvetrain if I'm going to run into any significant problems. Thanks again.
Car: '91 RS Camaro
racing28x
04-25-2016 03:54 PM
goalieforlife
22
03-31-2016 12:16 PM
