Digital dash swap questions BBC
Hey there, I'm picking up a roller this weekend with intentions of dropping a carbed 454 700r4 combo into it.
few questions and I've read the stickies.
how does the digital dash effect me? Also ecm? Does that have any play with what I'm doing? I'm intending on running the 700r4 so I'm not too worried trans wise. Just curious if I'm going to have issues elsewhere as I've seen nothing about the digital dash. I had an 87 but it was standard gauges.
Car: 91 Trans Am
Engine: LSA
Transmission: T56 AWD
Axle/Gears: 8.8 4.10
Re: Digital dash swap questions BBC
Its an analog dash for camaros
Speedo is cable
tach electric off the dist
coolant, use 3rd gen sender, one wire to the C100
Oil, use 3rd gen sender one wire to the C100
Alt, no change
Fuel, no change
Dont forget the two large red cables from the C100. These need battery 12v or nothing in the car will work. Ground the Blk/wht wire at the C207 pin M or none of your gauges will register
Speedo is cable
Alt, no change
Fuel, no change
camaro_V6_Tuner
03-16-2004 10:16 PM
camaro_V6_Tuner
03-13-2004 11:49 PM
