vortec motor and heads
Engine: soon to be changed 3.1
Transmission: soon to be changed 700R2
Ok, first i need help finding a spring kit. I'm getting a vortec motor and heads. I know the vortec heads can't handle much lift, but i have seen a spring kit that will allow for a .550 lift without any machine work to the heads.i am having trouble finding that again. Does anyone know where i can find that again? And second, i plan on keeping the stock bore probably ringing it. But anyone have good ideas for a 400-450hp build? Good can, rockers intake etc.. Any advice is appreciated. Thanks.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Car: 92 Firebird, 91 Trans Am
Engine: L31 with HSR, LB9
Transmission: 700R4, 700R4
Axle/Gears: '99 10 bolt 3.90, '01 10 bolt 3.42
Re: vortec motor and heads
You'll need a good intake (Carb or EfI, and Probably at least a 280 XFI cam with 1.6 rockers.
Location: Close to Boggstown Indiana ( out in the middle of a corn field)
1 Post
Car: 89 Iroc, saved from scrapyard
Engine: 350 vortec w/stealth ram
Transmission: 85 corvette 700r4
Axle/Gears: 3.73 posi
Car: 82 Z28
Transmission: T400
Plenty of Vortec build info out there
How big is your wallet?
http://www.hotrod.com/techarticles/e...k_chevy_build/
http://www.popularhotrodding.com/eng...c_small_block/
http://www.chevyhiperformance.com/te...e_roller_cams/
http://www.chevyhiperformance.com/te...cam_355_build/
84z96L31vortec
08-20-2017 12:16 AM
theshackle
03-05-2017 06:37 PM
