350 swap in my 1988 Firebird Formula
Old 05-06-2013, 06:51 PM
DD9TransAmGTA's Avatar
Car: 1987 TA GTA, 1987 IROC 1988 Formula
Engine: 350 tpi/305 tpi/350 tbi
Transmission: All have 700r4's
Axle/Gears: 10 bolt with 3:73's
Ok so I had a knock/rattle in my engine so I pulled the pan off, and I find the rod cap is burn't and it spun a bearing. So I thought I could get away with replacing it, little did I find out the crank is, lets just say toast. So I just got the engine out this weekend. Now I'm waiting on the engine to arrive, it's a 5.7 350 TBI out of a 1993 Silverado 1500 2WD. Nothing special, but I'm going to freshen it up and enjoy it. My list of things to replace/do is Smog delete belt, upper hoses, Transmission seals, transmission mount, plug wires, paint maifolds, cap and rotor replacement, oil and filter. I complete deleted the emissions junk and plugged the manifolds where the old air tubes were. The car had 2 1/4" Straight pipes on it and I immediately cut that off. I'm replacing that with a 3" stainless Borla system, should have a much better sound .
Heres some pictures
And my custom painted black pearl air cleaner
xkingcodex
02-12-2020 07:43 PM
theshackle
03-05-2017 06:37 PM
bellez77
09-05-2015 08:39 PM
Randomtask2
08-13-2015 01:57 AM
armybyrd
08-10-2015 09:23 PM
Quick Reply: 350 swap in my 1988 Firebird Formula
