L31 Engine Question ???
#52
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: L31 Engine Question ???
I have no idea , whatever the stock pump puts out .
#55
nothing as of yet . I plan on putting a few more miles before I decide if I need to . I do want to eliminate VATS & EGR on the computer . good luck ...
#56
Car: 1989 Firebird, And soon 1989 Iroc
Engine: Firebird 5.0, Iroc vortec 350
uncle, Im doing this same swap got the motor in but having a starter issue. Did you use the stock starter and flex plate, or something
else?
else?
#57
I used my stock starter from the old 305 . I also used the same flywheel . I have a T-5 manual transmission (much more fun than an auto.) . for an auto. I'm afraid I cant help you . I'm sure some others on this forum could help you . good luck .
#58
Uncle Tom I have my car running with the l31 but doesn't seem to be running right. It dies around 2500 rpms. Do you have 350 injectors in yours? I have a bored throttle body and 350 injectors. I did buy a custom chip. Are you also using the stock 305 chip? And what did you set your timing at?
#59
everything is stock from the 305 . timing is about 8-9 degrees , I worked up from 6 degrees . I suspect your timing is off & other ignition/fuel problems . my engine was a NEW G.M. crate engine . all engine sensors/switches I used were NEW . the distributor & wires were almost new , I also used NEW sparkplugs for a 2001 truck engine . the plugs are different . my fuel pump & filter were pretty new . good luck ...
#60
Car: 89 Firebird
Engine: 355 TBI
Uncle Tom if your car continues to run so good you make it a hard decision for me not to buy and just drop the stock L31 in mine for the simplicity of it. Id love to see dyno results or 1/4 times on that car just as an idea of the power its making on the 305 tune.
#61
Mine is a brand new crate motor, all new items as well. Nothing is reused from the 305 on the motor. Yep I have new plugs for a 2001 truck.
#62
I did re-cam the engine , I took my time on everything . I was overly **** on ALL details . dyno results , 1/4 mile times ??? yes I suppose it would be interesting to know . will I find out ? most likely not , I really don't care . I'm 76 years old , all I wanted was a few more pony's under the pedal . (never expected this much response on my engine swap) I'm very happy with my swap . good luck if you do the same ...
#63
Car: 89 Firebird
Engine: 355 TBI
Thanks Unc, id love to run into you in Oct at cruising the coast and check out your car. I may go the same route as you did.
#64
if I'm still kicking I will be there . I'm pretty close , I live in wade so it's not much of a drive . I always enjoy but never get to see everything . always much to see & do . good luck ...
#65
Uncle tom I completed my swap and yes this engine does pull like a bat out of hell. My issue was the iat sensor wire was bad and causing all kind of issues. Fixed that and now it drives excellent.
Your post was my inspiration to do the same swap.
I do have slight differences. I kept the stock cam in it. I ordered the motor from summit. I did add a bored out tbi unit, hooker headers, delete cat, hooker catback, 350 injectors, 350 module and custom tune, 3.73 gears and posi unit. Ill take some pictures when the weather clears in my area. I don't want to pull it out of the garage in the rain.
#67
#68
Car: 1987 Trans am
Engine: 350 Vortec Stealth Ram
Axle/Gears: 02 SS Torsen Zexel 3.42
Hope you don't mind if I chime in. I'm also doing a L31 swap and have heard some good and bad about the vortec plastic timing cover. Notorious for leaks where it meets the block. The instructions say to apply a bead of RTV on part of the bottom of the timing cover onto the part of the block. And I'm assuming the pan gasket goes over this. Can anyone say exactly where the RTV needs to go? It's on the stand now and I'd hate to have to come back to this. Timing cover is brand new. I went with a 93 LT1 cam, didn't need special springs so I was told cause the lift was supported by the 906 heads in stock form.
#69
WOW I created a monster when I started this thread . (damn I love it) I also wondered about the plastic cover . on the RTV , with the pan off a dab of RTV on each corner where the pan gasket forms around timing cover and rear main . in the groove on bottom of cover & rear main just a light coating of RTV . I must admit I messed up (my fault) the crank seal and had a bad leak . the plastic cover does not like crank seal only to be replaced . after 2 try's I replaced the entire cover . (GM recommends this for crank seal leak) as do I now . anyway all is fine now . HINT , when using RTV on anything just tighten down finger tight at first . take a break , have a beer , coffee , or what ever . let the RTV cure a bit before final torque . once again I am very happy with my choice of a new GM crate engine . I got mine from JEGS , 2K delivered to my door . would have cost much more had I sourced & rebuilt a JY engine . good luck with your project ...
#70
Car: 1990 1/2 Firebird Formula 350
Engine: 350 l98/l31 TPI Vortec Ramjet
Transmission: 700R4 Shift kit, vette servo
Axle/Gears: WS6 3:27
L31 block, 906 Vortec heads, 395 Ramjet cam, (thanks gary1, and Uncle Tom) SD intake manifold, Hooker 2460 shorty's, custom 3" Y pipe and exhaust, few bolt-on's, l98 pulley's, plenum, wire harness, map/speed density, etc.
I ditched that plastic cover right off the rip.. granted I had the one off my l98 layin' around. Why take a chance if you're uncertain, or have heard bad things.. that's the way I look at it anyways. This has been such a helpful thread! Thanks all!!
#71
Car: 1987 Trans am
#72
Thank you. Talk about looking great... you got a beast there man!!! I'm really wishing here recently I went with a Ram. O-well, maybe next year, lol. Yeah, mines also a 97 Tahoe block/heads. But that's all I used. The rest of the 90k mile "running truck" parts are in my garage, lol. I used everything off my l98. Water pump with hole, (so I could run the coolant bypass) l98 harmonic balancer, all pulleys, OIL PAN (didn't wanna chance dipstick accuracy, etc.)
#73
I see you're in FLA L98GTA87, get that beast dropped in man and meet me up in Daytona for the Turkey Run in November!!
#74
Car: 1987 Trans am
It'll definitely be in by then but sounds good to me! I hope I'll be okay with using some of the vortec parts. I'll be using the vortec balancer, oil pan with dipstick. Pretty sure pan will be fince especially as all the auto part stores lists the same one for a 87 T/A 350 and a 97 Tahoe 350. Everything else I will use from the L98. I started it up on the stand today, here's a video.
#75
Awesome man!!! You should be fine.. I just made it easy on myself putting everything back on that came off (dummy proof) lol. I did use a power master high torque mini starter, and the 168 tooth flexplate off the l31. I always forget to mention that. Had to use the mini starter cause of the headers. Had to fab my own dust shield too.
#76
Car: 1987 Trans am
Right on. My GTA is my daily so don't have any l98 stuff laying around yet. This is going in because I have low compression on one cylinder, but still runs great. I noticed the staggered starter and large flexplate. I'll be using a LT1 starter and flywheel as a T5 will be going behind it.
#77
Car: 1987 Trans am
I can't find anything but did anybody have to switch to a longer serpentine belt when they did the swap? My l98 belt was insanely short and I used all pulleys and brackets from my l98. I bought a longer belt but what gives?
#78
NORMAL , with the elimination of air pump . I know sounds weird but routing of belt is different and does require a longer belt . good luck ...
#79
OR I've in the past dumbed out on which way it went... It's one of those last exciting steps, the belt then the radiator/fans then DRIVE! Easy for me to get overly excited and start dumbing stuff up, lol. Me anyways.
#80
Car: 1987 Trans am
#81
LMFAO!!! Kick *** man!! Looks fantastic!! It's good to know I'm not the only one that did that also.. I took a trip to the parts store and wasted money too. And the screwed up part is that I was trying to find a routing pic on my phone (there's not one in Chilton's) and couldn't find one ANYWHERE online, not even on this site. After I figured it out I was sliding the fans in and realized there's a damn diagram right there on the fan shroud, lolol.. hints the reason I posted that pic for ya..
#82
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
There's two ways to route the belt... short vs long. Belt lengths from AdvanceAutoParts
98.03" = Air - crank - water pump - power steering (88), or...
94.50" = Air - water pump - crank - power steering (89-92) as see in the previous pictures.
Thank to SEThirdGen for the diagrams (88 vs 89-92):
#83
Car: 1987 Trans am
#84
If you have the routing in the 2nd diagram and take off the smog pump, if you use the routing in the first 1st diagram, minus the smog pump, you can use the original belt.
#86
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
Just wondering is plastic timing chain cover required? I used a timing cover off another sbc engine that was laying in shop.
#87
I'm not sure , but I don't see why not . remember the timing mark will be at 2 o'clock now . if it (the metal cover) does not have it in that location you will have to add one . good luck . cheers ...........
#88
Car: 1991 Z28
Just thought I'd drop a word on the vortec coolant bypass - if any of you guys are not running coolant constantly through your heater core, then the intake manifold needs a coolant route plumbed into the water pump intake. This is because the vortec heads and block do not have internal coolant bypass like the old heads have. This prevents hot spots from forming in your coolant passages when the engine is warming up.
Awesome builds, guys! I'm working on mine too, and hope to have pictures to show soon enough.
#89
Car: 1987 Trans am
What plugs and plug gaps are you guys running with your efi vortec setups?
#90
Car: 1983 G20 Chevy
Transmission: 4L60
#92
Car: 1933 Ford Sedan, 1934 Ford Pickup
Engine: 350 Chevy
Transmission: 700 r 4
Wondering what plug wires you guys are using. I am converting a L-31 to a carb. Thanks
#94
HI uncle tom whot did you do with the chip ? many say cant run stock others disagree gathering parts to do same as you but mine is a 700r4 glad u ok thanks steve
#98
What Horsepower are you getting with that setup? Lately I've been leaning towards swaping out my l98 to go to a L31 with the tuned port setup to keep it looking stock.
#99
#100
sorry to bring up old thread, kinda unclear on a few things. So, the stock computer will work? Gauges?
