305 carburated to 350 carburated flywheel problem
We have an 87 camaro that has a 305 carbureated motor and a 700r4 transmission. We are swapping it with an 1982 350 motor but need to know what flywheel to use. Can someone please help?
Re: 305 carburated to 350 carburated flywheel problem
Do you know any websites where you can order them at? were also trying to figure out how many teeth it needs to have on it.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
153 teeth, common as dirt
http://summitracing.com
http://jegs.com
http://rockauto.com
http://napaonline.com
http://jegs.com
http://rockauto.com
1982, 1991, 305, 350, 87, cadillac, carborated, carbuerated, carbureted, engine, fbody, fit, flywheel, swap, z71
