350 swap confusion and frustration
Car: 86 z
Transmission: Factory 5 speed
Ok so i have 86 z28 with the factory five speed and a 305. I bought a bult 350 from a guy that used it in his 81z. It is a two piece main crank older engine. I cant seem to get any info on what exactly i need to do to get the factory tranny and the oldee engine married. The 350 flywheel doesnt fit inside the .bell. so can i put a different bell housing on and have it clear the wall? Is there anyway to get a smaller flywheel for the three fifty? If so how would the starter work? Do i need a compleatly new tranny? Any help out there?
Car: 86 z
Re: 350 swap confusion and frustration
Nobody can help me out? Ok i guess i could just cut the bottom of the bell housing out with a sawzall so the flywheel will clear. What have i got to loose right?
If it is a 2 piece rear main sounds like you need the correct bell housing or new flywheel from a 85. I think there is a 10 , 10.5 and 11, 14 flywheels . measure you old one form the 305 and goto rock auto.com and look one up for a 85 camaro. You also need to use the right disc and pressure plate for that flywheel. I think the 14 is the 168.
Car: 86 z
The larger flywheel hits the bell housing on the bottom. So is there a bell housing for that tranny that will fit inside the firewall that will also clear the flywheel?
Car: 86 z
So by using the 305 starter i can use a 153 tooth flywheel. So i just need a new flywheel and preasure plate. Because the small preasure plate doesnt bolt to the other flywheel
not sure about your bell housing options I assume your using a t5. I would get a smaller flywheel. wish I had more experience to answer you 100%. but I do know 85 was a 2 piece rear main seal so if you measure the diameter of the flywheel that should work. I want to say it was 10.5 and 153.
the 153 starter holes are straight across from each other and the 168 are staggered.
Car: 86 z
O ok i was unaware that the 85 had a two piece rear main seal. So that clutch should all of my problema then. Thanks for the help. Ive had the junk yards and parts store running in circles for a week and noone can seem to figure it out. I guess i should have came on hear a week ago. Live and learn
I think you need a acdelco 388017 ( g.m 88990367) or equivalent. I took that part number and went to acdelco.com and it shows to be used on 101 different chevy applications from 1966-1985. It says to work with the 10 and 10.4 clutch but does not give the external diameter but I think its 12 3/4 153 teeth compared to the 168 14 inch flywheel. as long as you don't get one for a 400 sbc should fit the bill.
Car: 86 z
I found one at the local junkyard. They want $200 for it! Isnt a new one less than that? I cant get the acdelco website to cooperate for some reason. Im sure now i know what i need i can go to oreiley or napa and get one. Maybe by sunday i can be cruzing again! Well see. Thanks again.
