TH350 Swap - Speedo Fix
Spoke with Dakota Digital and they have what is required to run your stock speedo with a TH350/TH400 see below...
Hi Rick,
According to our information, the stock speedometer in your car is looking for a 4K PPM signal. We have a pulse generator (SEN-01-1) that will thread onto your TH350, but it outputs an 8K signal. With the use of our SGI-5, you’ll be able to calibrate the speedometer with whatever tires and gears in the car, and can always recalibrate for changes made.
SEN-01-1:
http://www.dakotadigital.com/index.c...rod/prd620.htm
SGI-5:
http://www.dakotadigital.com/index.c...rod/prd126.htm
Hi Rick,
SEN-01-1:
SGI-5:
Street Lethal
04-30-2019 12:14 PM
ambainb
04-25-2016 09:21 PM
beachrodder
08-07-2015 04:27 PM
