HEI wires over valve cover or under headers
Car: 89 Formula
Axle/Gears: 9 Bolt 3.27
Guys,
Which one spark plug wire sets would be longer or the better choice.
the over the valve cover or under the header wires spark plug wire set?
JP
JP
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Under the header would be longer.
There may be exceptions, but at least for the Hooker 2055's that I used, over the valve cover made for a cleaner install, with less of a possibility of wire damage from heat.
Car: 89 Formula
Re: HEI wires over valve cover or under headers
Thanks. I figure go with the experience that other have tried.
NBrehm
08-25-2015 11:49 PM
Street Lethal
08-12-2015 11:33 AM
